Review and disassembly: Thorfire VG10S
16 posts / 0 new
XXX-Man
XXX-Man's picture
Last seen: 16 hours 52 min ago
Flashlight was provided from Thorfire for free as a replacement for bad VG10.
Very similar with Sofirn SF36 I reviewed before so I will use some text from that review on identical things.
Specifications from manual:
LED: Cree XP-L, 1100 Lumen, 13200cd (mine has same LED as Sofirn SF36 and it’s XP-L2 V6-2A-D, 5350-5700K)
Operating voltage: 2.8-4.2V
Battery: 1× 18650 Battery
Switch: backward tail clicky
Size: 13.4cm length, 2.6 / 3.3cm diameter, 133g (without battery)
Material: 6063 Aircraft aluminum with Type III anodization
Reflector: smooth
Battery warning: Blinks 2x/sec. And turns off one minute later
Deep discharge protection: yes, at 2.8V
Lens: Hardened glass lance with AR coating
Waterproof: IPX-8 (2 meters for 30 minutes)
5 Mode: High 1100lm 15min; Mid 300lm 2h45min; Low 50lm 22h; Firefly 1lm 200h; Strobe 1100lm 45min;
Mode Memory: yes
Tail-stand: yes
Package:
Thorfire VG10S, manual, belt clip, 2x o-ring
Flashlight has nice feel and looks good quality.
Threads are square but little thin. They are anodised and came well lubricated.
Tube is not reversable.
Threads are not compatible with VG10 version, but are with Sofirn SF36, so you can use SF36 tailcap.
Tail switch is reverse clicky mounted on 17mm board. It has nice click.
Flashlight can tailstand without problems.
Driver is 19mm, bigger driver won’t fit. It’s fixed with retaining ring.
Wires to LED are 24AWG
It has 4 modes with memory and strobe on double click. Modes are nicely spread.
Head has SS bezel. Glass is 27×2mm AR coated and reflector is SMO. AR coating is very light, but it’s there.
There is o-ring between glass nad reflector and reflector has groove for o-ring to sit nicely.
Exactly same bezel and glass is on Sofirn SF36. Reflector is similar but not the same (or just some manufacturing difference.
LED is XP-L2 and is on 17×1,6mm copper board.
There is 1 screw holding board to shelf. Shelf is fixed, so no pill.
There is good amound of thermal paste between board and shelf.
Flashlight is 134mm long, diameter is 26mm at tail and 32,5mm at head.
Comparison picture with Thorefire VG10 and Sofirn SF36
Current measurements:
Cheap dmm, not sure how accurate it is so I made measurements on some other flashlights to compare.
Used ICR18650-26C battery
SF36 VG10S VG10 S2+ 6*7135
Moon 0,03A 0,01A 0,01A
Low 0,16A 0,15A 0,09A 0,18A
Med 0,98A 0,93A 0,77A 0,92A
High 3,20A 3,10A 2,51A 2,13A
“The saddest aspect of life right now is that science gathers knowledge faster than society gathers wisdom.” - Isaac Asimov
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F /// Zanflare F1
Edited by: XXX-Man on 05/01/2018 - 06:03
desmondkun
Last seen: 2 hours 54 min ago
Wow!! VG10S!!
Better heat conduction and higher amp draw but too bad, no tactical ring is a down point for me. I’m not sure how much more lumen compare with xp-l. Will you psot some beam shots?
Thanks. Big Smile
Take care of your flashlight and your flashlight will take care of you.
Lightbringer
Lightbringer's picture
Last seen: 9 hours 19 min ago
Want mine? Big Smile
On my VG-10, I took off the ring and clip before I even put the battery in. To me, they just get in the way.
XXX-Man
XXX-Man's picture
I will post beam shots in next few days, when I get some time to do it right.
And when I get some nice camera to do it…
My reviews:
NeutralFan
NeutralFan's picture
Last seen: 2 hours 43 min ago
Looks like a nice flashlight, thanks for the review XXX-Man. I wonder why ThorFire only used 1 screw for the LED MCPCB? If I got the flashlight, I would need to add another screw to the other side to help tighten the LED to the shelf.
I’d rather use my flashlight around the house than turn on the lights.
XXX-Man
XXX-Man's picture
No idea why only 1 screw.
Also it’s very short.
Best to get 2 little longer screws to make it good.
My reviews:
desmondkun
[quote=On my VG-10, I took off the ring and clip before I even put the battery in. To me, they just get in the way.[/quote]
Get in the way !? That’s a manly part of flashlights for me. Big Smile
lights_on_bikes
Last seen: 3 years 2 months ago
I tested my VG-10S and I’m only getting 2.4 amps with a fully charged battery (4.15 v). I’m getting ~2.1 amps on my old VG-10. Both seem pretty bright, but no where near what most reviewers are saying in terms of current.
I’m using these batteries:
https://www.orbtronic.com/3600mah-18650-li-ion-orbtronic-panasonic-recha… (link is external)
Any ideas why the current is so low? I believe I have them both on their highest setting, unless there is a special mode?
XXX-Man
XXX-Man's picture
Could be bad meter?
My reviews:
lights_on_bikes
I used a Fluke 87V. Also verified with a cheapo meter.
Are you all using unprotected cells?
XXX-Man
XXX-Man's picture
Then your measuring should be good.
I am using unprotected LG HG2
My reviews:
lights_on_bikes
Have you modified the springs for lower resistance?
Maybe I’ll try an unprotected cell.
Any recommendations between the 3500 mAh cells? Looking for highest capacity, low internal resistance.
https://www.orbtronic.com/samsung-35e-18650-battery-inr1865035e-flat-top
https://www.orbtronic.com/sony-vc7-18650-3500mah-li-ion-rechargeable-bat...
https://www.orbtronic.com/18650-battery-3500mah-li-ion-high-drain-panaso...
XXX-Man
XXX-Man's picture
Springs are bypassed.
I only have 35E and didn’t test them yet so nothing smart from me to say about it Smile
My reviews:
lights_on_bikes
How did you bypass the springs? Can you post photos?
FmC
FmC's picture
A clamp meter is the way to go for more accurate current readings. Are you by chance using the standard leads that came with your meter? If so, they will most certainly be the culprit.
https://www.youtube.com/watch?v=_K_46vs_Zpk&feature=youtu.be
lights_on_bikes
Hmm. Yeah, hadn’t thought about the resistance of the leads being significant, since they are high quality fluke leads. I’ll try some 12GA wire or a sense resistor.
