Yesterday I got the two Elfeland F1010; Immediate internal accuration work (oring + reflector height); Now they work very well; The charger is samsung and stops charging at 4.18 volts.
I really like it Trev, very small/compact/light(little smooth in feel but the clip helps out some). The xhp35 4500k is very nice, very bright to. Trick driver steps down and manages heat very well. It gets toasty, but its hard to tell the subtle drop/s. UI as you will know is good, not as deep as the sc5c mkII’s with 3 groups to program.
Very light, ideal for edc and plenty of output if/when needed.
Next ZL will be the 600 flood(xhp50 hi cri) with the frosted lens…………….
One of the reasons i picked this over the mkIII was size and design, just a little different and as it is a little love/hate in design, it made me want this one more.
Thanks!! probably I will go for the SC63, I need a little of “control”….manker E14 II, Emisar D4, S41S are power without control (adorable of course), but sometimes I like have more moderate options … like this SC63 in the pocket
