@BanL
I apologize if this has been been raised before (couldn’t find anything after going through a few pages):
Would Kaidomain potentially be able to source or manufacture quad DTP copper MCPCBs /w optics? With or without emitters on them? Either 20mm in diameter or maybe larger?
I don’t know if I should be posting this here, but it has to do with KD products.
Does anyone know if the following drivers work with 14500 Li-Ion batteries?
This driver will work for your voltage range, but it is L-H-Strobe. I have ordered one of the CF-17mm drivers recently, so I can let you know if 14500 works when it arrives.
@ dekozn
Thanks for the tip! I sent PM to WWEFANS asking about the driver, if has them and if I can buy one from him! Thanks for the information!!
@ Jensen567
Hum, I really wanted a (ML-)L-M-H driver, if possible without stobre. I’ve seen the one you linked, but it doesn’t fit my needs!
When you receive the CF-17 driver, please let me know if it works with the 14500! Just don’t damage it trying the battery!
Both Reylight and that Lumintop are what I want, concering the mode specs, but I would like to mod a light instead of buying another one. One must see what is affordable in the moment… :money_mouth_face:
I’ll wait for the answer of WWEFANS and also your feedback, please!
I received today an answer from KD store in AliExpress (I asked about the drivers above mentioned as well).
The “CF 17mm 0.9V - 3.3V 4 Groups 2 to 5-Mode” *doesn’t work *with 14500 battery!
Probably the one you linked works with it, but I won’t try it for now!
I asked WWEFANS some drivers and we’re in contact!
Thanks for your answers :+1:
I’ve seen several reports of this happening. Most of them have been using a FET driver so high current, but well below the max current that djozz tested. I wonder if the attachment of these flip-chip dies to the underlying substrate is not robust and can be disrupted by shock or thermal cycling.
I had the same thing happen to one of my XHP50.2, but I also have two still working fine : one in a Thorfire C8s with a H1-A driver and a Jaxman M2 with a LD-3 driver driven @ 6A.
Roughly 30% of the input power leaves as light, but this doesn’t mean the reflector is heated significantly. The reflector might absorb 10% of the light, so all together maybe 3% of the power is heating the reflector.
