Not a bad idea. It hadn’t occurred to me, so I haven’t given much thought yet to the implications of it. But I do know that on a technical level it would be much harder for me to implement with the available tools and frameworks I have for this forum.
Hi Sb. No problem, I don’t feel as though you have come down on me at all.
It is no secret I am the person with 48 Rude votes, down from 53 I might add.
When I PM’d you about this you kindly responded with some directives. I replied that I would make a very conscious effort to comply with those directives. And I have.
Yes, I as well as others do not necessarily like the anonymous system, for reasons stated…… BUT, this is “your house” & you set the tone as well as rules.
That is good enough for me. :+1:
How about a system where the first, let’s say 4 rude registrations are invisible? This means “noise” will be filtered out to the member to avoid a negative experience. If a post is truly rude, it will most likely receive more than 5 rude registrations, and then it will become visible to the poster as a more genuine feedback. Just an idea…
Very good idea, thanks! Not sure yet how difficult that would be technically to implement.
Not always, because eventually a post will disappear if many different users mark it as rude. But it is theoretically possible for a lot of people to load the page at approximately the same time, see the rude post, and mark it as rude before it gets automatically removed.
Diagnosis: “are too!” “am not!” exchanged, over and over.
Last time I got a rude point, it was because I expressed an opinion.
I assume whoever dinged that comment did so instead of posting a public response.
For which self-control I thank whoever it was.
I looked and realized, yeah, I could have irritated someone.
It’s a good tool, working well, I think.
Appologies in advance SB… I am going to click on your Rude button in post #74 just to see if there is another page to confirm the submission.
Just curious if there is a chance of accidental submissions as the Rude is close to reply button.
For all the discussion on the Rude button, SB’s stats show it does not get used often. With all the members here, only 4 have active points. I for one can’t remember the last time I clicked Rude. I think I used it a few times the week it was introduced, and not since. I like it, but don’t really use it. But before it was introduced I had a big need once.
