26650 power bank light
7 posts / 0 new
power911
power911's picture
Last seen: 3 weeks 1 day ago
This light
Dodgy looking charger bank but it looks like a solid light to me.
Plus the ability to change driver.
Any comments before I put this in my Christmas wish list?
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
vwpieces
vwpieces's picture
Kaidomain sells that light as JKK26 for about the same price but with better LED choices.
I have one in my cart from their Aliexpress store, just haven’t hit the buy button yet.
JKK26 Cree XP-L HI White 6500K / Neutral White 4500K 980 Lumens LED Flashlight with USB Charging Head – Black ( 1×18650/1×26650
If you don’t have to have the USB charge/Batt Bank I suggest the Eagle Eye X7 on Gearbest. X7 can be modded to a triple if you wish. Uses 20mm driver.
power911
power911's picture
Kaidomain sounds like good news.
X7 meh. I’d go with X5r or zanflare f1 if needed in that charging format.
Barkuti
Barkuti's picture
Last seen: 4 hours 23 min ago
vwpieces wrote:
If you don't have to have the USB charge/Batt Bank I suggest the Eagle Eye X7 on Gearbest. X7 can be modded to a triple if you wish. Uses 20mm driver.
Looks like a very nice 26650 host with smooth reflector. What kind of stock driver does it uses?
I'd slam an LD-29 in it, or maybe an H1-A boost engine and a dedomed XHP50, or sort of.
The human mind, and its programming, is at the forefront of a particular battle of The Light vs evil dark forces. Nearly every human being on this beautiful planet “Earth” has some sort of negative mind programming in its mind. And you better take care of your mind programming, or someone else will in this wicked world.
Please avoid fully quoting lenghty posts, namely with nested quotes. Trim quotes down to the essential. Helps with neatness and legibility. Thanks.
I recommend saying no to Covid vaccine. Listen to your spirit or soul. Innocent
Keanu Reeves may need your help. Join his Telegram channel here.
The Miller
The Miller's picture
Last seen: 2 years 1 week ago
Anybody actually have this light?
how is the charging and powerbank function? looks nice IMHO
AlexGT
AlexGT's picture
Last seen: 2 days 2 hours ago
I have the JKK-13 and is a good flashlight, the charger powerbank works good!
Here is some info from a while back.
http://budgetlightforum.com/node/30596?page=1
glide 1
Last seen: 2 years 10 months ago
I have this light purchased from the Aliexpress seller. Light is solid, well built, and powerbank/USB charging all seem to work ok. One has to unscrew the head to access charge port and to use it as a powerbank however, i find myself not knowing what to do with the head when doing so Smile
@Barkuti – The Ali version came with an XML with a 6×3175 board. Driver board is 20mm but shelf is too shallow for an H1-A and will not fit.
I have since replaced the emitter to an XPL HI and piggy backed a few 3175’s, like it more now. $20 it makes a good bedside light.
