KD (kaidomain): Deals and new products thread
This driver will work for your voltage range, but it is L-H-Strobe. I have ordered one of the CF-17mm drivers recently, so I can let you know if 14500 works when it arrives.
http://www.kaidomain.com/p/S024883.17mm-0_9V-3_6V-3-Mode-Boost-Driver-Circuit-Board
Not sure where you could purchase one but the driver out of a Lumintop Prince Mini sounds like exactly what you are looking for.
@ dekozn
Thanks for the tip! I sent PM to WWEFANS asking about the driver, if has them and if I can buy one from him! Thanks for the information!!
@ Jensen567
Hum, I really wanted a (ML-)L-M-H driver, if possible without stobre. I’ve seen the one you linked, but it doesn’t fit my needs!
When you receive the CF-17 driver, please let me know if it works with the 14500! Just don’t damage it trying the battery!
Both Reylight and that Lumintop are what I want, concering the mode specs, but I would like to mod a light instead of buying another one. One must see what is affordable in the moment… :money_mouth_face:
I’ll wait for the answer of WWEFANS and also your feedback, please!
Thanks in advance! :+1:
I received today an answer from KD store in AliExpress (I asked about the drivers above mentioned as well).
The “CF 17mm 0.9V - 3.3V 4 Groups 2 to 5-Mode” *doesn’t work *with 14500 battery!
Probably the one you linked works with it, but I won’t try it for now!
I asked WWEFANS some drivers and we’re in contact!
Thanks for your answers :+1:
Sent BanL the following question via PM five days ago. I believe it's worth sharing:
Three days later…
I believe the yellow top switch is adequate, it's no problem for me to solder it a copper sheet lead elongation.
If anyone is willing to contribute some additional worthwhile information, you're welcome.
Sorry for replying you late.
There is too many different SK98s in the market.
And the above two flashlight switches does not fit for the SK98 flashlight.
Thank you
Ban
my c8.2 xhp50.2 led 2die has dead
Modded or stock?
stock.
I’ve just been using it for a few 10 or 15 minutes.
I’ve seen several reports of this happening. Most of them have been using a FET driver so high current, but well below the max current that djozz tested. I wonder if the attachment of these flip-chip dies to the underlying substrate is not robust and can be disrupted by shock or thermal cycling.
I have a C8.2 here that i’m reviewing , it still runs great after 5 full runs on max setting (5* 45 mins) , without a fan etc .
I had the same thing happen to one of my XHP50.2, but I also have two still working fine : one in a Thorfire C8s with a H1-A driver and a Jaxman M2 with a LD-3 driver driven @ 6A.
Been looking at this light thinking about getting one.Would appreciate your opinion on it.
Hi delete
Please let me know more about the flashlight problem.
All the flashlights before we shipped out has been done a full battery testing.
I would like to see what is the matter and see how to improve it.
Thank you
Ban
Roughly 30% of the input power leaves as light, but this doesn’t mean the reflector is heated significantly. The reflector might absorb 10% of the light, so all together maybe 3% of the power is heating the reflector.
The pill has a very good fit , i don’t think this is the problem…
Seriously? For every flashlight before shipping it out you need to run it on high mode for about 40 mins?
Hi
Yes, for the KDLITKER flashlight, it will turn on the Hi-mode and run for at least 30 mins until the low voltage warning appear (Light is flashing).
Thank you
Ban
It’s awful. You have to enter text the exact way it appears in the product title in order to get anything to show up.
Thank for your advice.
We will keep improving on our system.
If you get any error or not functioning well, please let me know.
Thank you
Ban
That’s impressive testing. Good to know.
