HKJ
(HKJ)
July 12, 2017, 4:03pm
125
No, but it looks interesting. With the amount of chargers I have in queue just now, I will not order new chargers for test.
At a later day I expect to check this thread for interesting chargers.
start90a
(start90a)
July 21, 2017, 3:04pm
126
I remember for that later day also a Nitecore SC4 .
HKJ
(HKJ)
July 21, 2017, 3:18pm
127
I have made a memo in the second post of the thread.
Pete7874
(Pete7874)
July 26, 2017, 8:53pm
128
Pete7874
(Pete7874)
July 26, 2017, 9:18pm
130
TheBo:
10 amps……. O_O
It’s 8 Amps max (4x2A), if I’m reading it correctly.
The outer bays can push 3 Amps only when the two inner bays aren’t being used.
The main negative I see is that there is no discharge function and no ability to measure actual battery capacity in mAh.
TheBo
(TheBo)
July 26, 2017, 9:20pm
131
Oh yes... I read it again... In my mind I have read ch2 and ch3 can only deliver 2A when 4 slot are used. My bad, seems time to sleep has arrived. Thank you for the clarification.
tempo
(tempo)
July 26, 2017, 9:36pm
132
Pete7874:
TheBo:
10 amps……. O_O
This looks like the most powerful charger on the market, 10 amps!!!
Or is there any more powerful, other than MC3000 ?
hank
(hank)
July 26, 2017, 11:49pm
133
Pete7874
(Pete7874)
July 27, 2017, 2:49pm
134
tempo:
Pete7874:
TheBo:
10 amps……. O_O
This Folomov one can do 8A max, same as MC3000.
TheBo
(TheBo)
July 27, 2017, 3:01pm
135
I'm not an owner of the MC3000, but by looking at the official spec (they could be wrong tho) they state 50W max charging power, should be able to handle 12A when in bulk charge then when you reach the ending voltage the termination current should be much less and compensate for that so, should be legit. I repeat, mereley looking at the spec...i could be worng, since i read the review long time ago
Pete7874
(Pete7874)
July 27, 2017, 3:08pm
136
TheBo:
I’m not an owner of the MC3000, but by looking at the official spec (they could be wrong tho) they state 50W max charging power, should be able to handle 12A when in bulk charge then when you reach the ending voltage the termination current should be much less and compensate for that so, should be legit. I repeat, mereley looking at the spec…i could be worng, since i read the review long time ago
Yes, I’ve seen mfg specs that state it can do 3A per slot, but HKJ review only indicates 2A per slot. Not sure why the discrepancy.
HKJ
(HKJ)
July 27, 2017, 3:22pm
137
I do have a 3A discharge curve:
!http://lygte-info.dk/pic/SkyRC/MC3000/SkyRC%20MC3000%20charge%203A%2012V%20(4xAWT18650-30).png !
There was a bug in my table with all chargers, it is fixed (There is probably more bugs in the table and I will fix them as fast as I know about them).
I am not going to fix the broken link.
Pete7874
(Pete7874)
July 27, 2017, 3:37pm
138
Thanks, HKJ. There is this table in your review that only shows current values up to 2A, and not even for 18650 batteries, so I wasn’t sure…
HKJ
(HKJ)
July 27, 2017, 4:00pm
139
Pete7874:
That is the recommended charger current for different cell sizes.
Pete7874
(Pete7874)
July 27, 2017, 4:31pm
140
Got it. Thanks for clarification. Looks like MC3000 is still the king.
will34
(will34)
August 6, 2017, 9:14am
141
It really is, the more time I spend with it the more I like it. The UI feels so easy to use now… (after a year)
rizky_p
(rizky_p)
August 6, 2017, 4:26pm
142
to go beyond 3A i think you’ll need hobby charger + 18650 holder and MC3000 is already expensive, but i dont charge my 18650s beyond 3A anyway, tried on 4A but got rather hot (samsung 30Q got 41C)
Barkuti
(Barkuti)
August 6, 2017, 4:46pm
143
HKJ:
I do have a 3A discharge curve: !http://lygte-info.dk/pic/SkyRC/MC3000/SkyRC%20MC3000%20charge%203A%2012V%20(4xAWT18650-30).png!
Fixed link. ;-)
You may want to switch to the advanced post editor , HKJ. Getting used to it may take some time, but the rewards are substantial.
hank
(hank)
August 10, 2017, 9:32pm
144
The email ad I got from illumn says:
A4 is a 4 slot smart charger with the capability of charging all 4 slots at 2A per slot. The outer two slots (slot 1 and slot 4) are capable of charging up to 3A when charging fewer than 4 batteries for your larger 26650 capacity batteries. Packed full of features such as LiFePO4 support, NiMh/NiCd charging capabilities, and 0V activation
