I know that the 4000k XP-L2 is far superior to the 5000k version I tried. The xhp70.2 is simply 4x xp-l2 dies put together, so I assume the results would be similar.
I am hoping to try some xhp70.2 myself before long.
When i saw FT has the XHP70.2 N4 3A in stock, i jumped the gun and ordered 3 of them for my MT03, because i really like the 3A tint.
My question is how big the difference in output is compared to the P2 binned versions.
Is it significant?
Should i have waited for an opportunity to get the P2 bin?
(I also got some TIRs for them by the way, i don’t think they will be nice with regular reflectors.)
Honestly you will not be able to tell the difference between bins. At this level of output the human eye is just not sensitive to notice unless you had them side by side.
Should be easy to tell from the CREE specs - I do this all the time. I think the percentage increase going up bin to bin is basically linear for higher amps, because the CREE specs will only show you low amp levels.
I think there is about a +–7% for each output bin. I’m not sure what the tolerance is for the 70.2. Anyway, you could get 1 emitter at the high end of N4 and 1 at the low end of P2 and measure almost the same output. Or they could be at opposite ends and you’d measure a big difference. You never know for sure unless you actually measure them.
I had a xhp70 N4 1A and a N4 1C and they were 6% off from each other. One of them was like an extra boost of power. You couldn’t see it with your eye, but you could measure it. It gave me a free 17 more meters of throw.
You might get lucky with a higher bin or you might not. So I wouldn’t worry too much about it.
You did measure different tints though. If you didn’t measure using a calibrated luxmeter with an expensive Filter, the difference might be due to the sensitivity to different wavelengths of your specific lux meter.
Slight differences in how LEDs are soldered (the thickness of the solder plays a role there) might also make a difference.
So in the end one can never be quite sure.
I would not think the tint of 1A and 1C would make much difference. They looked identical to my eyes. Wouldn’t it make more sense that they were just at different ends of the N4 binning range?
This is the wrong mindset.
If you say there is no visible difference between N4 and P2, then you can also say there is no visible difference between N2 and N4, then you say there is no visible difference between M4 and N2, etc etc etc.
Using that logic you will end up buying the lowest possible bin because there is no visible difference from the next one.
As a flashlight enthusiast forum, I would expect people to go for the best possible option, not “oh this one is good enough, no big difference”.
Yes there is a difference, and all the small things do add up in the end.
The Difference betwenn N2 and P2 is at least 7% and maximum 14%. Its the wrong conclusion if you say: if there is no differnence between N4 and P2 there will be no difference between the lowest and hightest bin.
Jason only said that there could be a difference between two binnings but there could be no difference too. Thats the normal shifting in the binning steps.
I've spent a lot of time and money to get an extra 5% output here and there, so a 5% or 7% to me is a big deal. I wouldn't down play 5%, but paying an extra $50 or so to get 5-7% (qty 3 of XHP70.2's) - you gotta think bout it. For a MT-03, 7% can go from 10,000 lumens to 10,700 - not a substantial gain but a bump none-the-less. For a MT03 though, it's worth popping out that pathetically thin MCPCB (1.5 mm at best) and checking the grease and surface under it. Mine had a drop or so that maybe covered only ~50% of the surface directly under the LED's, and the copper was tarnished from no surface protection - not good.
I tore the LED wires getting them out because of poor clearances, and screws holding the MCPCB down can stripped threads in the shelf, and the screws on the battery tube were severely stripped and angled in, damaging the threads.
My MT03 needs repairs to even make it moddable, and all these things you might not know about unless you looked.
You don’t understand, the difference between N4 and P2 is basically the same as the difference as N2 to N4 or M4 to N2.
So if your logic is “why pay more for P2 when you won’t see a difference from N4” then you can also say “why pay more for N4 when you won’t see a difference from N2” and then “why pay more for N2 when you won’t see a difference from M4”
The point is not that you should not aim for the highest bin. Of course you want the highest bin that you can practically get.
The key there is practically get. Getting the positive top level bin is almost always harder then going 1 step down. You are also generally going to pay more and be limited in the tint selection, usually cool white only.
For example Cutter generally had the best bins you will find but they are a nightmare to order from, the shipping makes the prices insane unless you are ordering in bulk and well, the communication is basically non-existent.
All of these things factored together, yeah I have no problem at all going with 1 step down for the best to get an LED that is the tint I want, from a supplier I want and at a better price.
This rule applies to most things in life honestly. Taking 1 step down in most things nets you a rather large increase in the bang-to-buck ratio.
Taking further steps down will end up giving diminishing returns of course.
This is also a budget flashlight site, so bang for the buck is always at the top of peoples lists when it comes to shopping.
I’m doing a total overhaul.
…but the progress is a bit like a slug in winter for now…
I got some nice TIR optic from Kiriba-ru to replace the reflector (less spill and eliminating the tint shift) and looking to replace the LED shelf with 4mm thick copper disc, but someone with a lathe will have to cut out the 1.5mm thin shelf…
Driver will be doing around 6.5 or 7 Amperes per XHP70.2
So that’s 120 Watts or more.
I’ll probably get some VTC5A batteries for it too.
Hoping to hit the 15000 Lumen. (okay 14000 maybe…)
So there's a TIR optic for a XHP70/XHP70.2? Interesting... I'm thinking ~8 XHP70.2's in a BLF GT .
In the MT03, vertical space is tight. Yea, the shelf is terribly thin. It's a waste of the thick metal body - just seems out of place for the walls to be so thick and the shelf so thin, and those thick plated copper plates between the cells and driver - nonsensical.
I replaced the stripped head screws on the battery tube today - had to use a dremel cutting blade to but slits in the tops of them, then use a regular screw driver to remove them.
Also drilled out clearance for the LED wires through the shelf, eliminated all the rough edges.
The BLF SRK v3.4 HQ driver is reflowed, set up as FET+1 using the Hyperion FET. Using DEL's new C3 and C4 caps in the design to tone down spikes the 7135 takes in these 2S high amp setups.
Yeah, very odd they did that.
I guess they wanted heat management for the driver?
They could better have used bigger FETs, diodes and coils i.m.o.
But by reducing the thickness of those discs i could gain a couple of milimeters vertical space.
Also the TIRs are a little less deep than the reflectors, and there’s some space between the optics and the glass lens too.
I think i can make the modifications fit.
I was thinking to make centre a hole in the copper shelf for the wires.
I’ll be using 18AWG.
That centre hole can be large too, since the thermal path goes to the outside.
For now i have only bypassed all springs, with a double bypass for the + spring of the battery compartment, i removed the inner spring.
Anyway, i have all the parts to continue the mod now, so i should go ahead soon.
