Just got my xpg2 3d today. Love this little green hulk.
Found I had to set the temperature higher on mine as I like to hover between 600 to 1000 lumens and thermal management was dropping me below 600 lumens after just a short time of use.
Now with it adjusted I am very happy with this purchase.
Do you mean the offset star? That’s a replacement star for the LEDs to sit on where each LED is rotated at a different angle so the corona is much more even and not square.
The offset star replaces the stock star. They use the same optic.
You can buy the offset star at Mountain Electronics
Is there a clip that works with this light? About to order two of them
I want to be able to strap it to my hat with the 18350 tube. Also will the s4 3D be a good choice?
Lost lumens going to the 319 but the color is a soft eggshell white and profile is nice, I think it’s worth the loss as the amperage went down as well.
No lights on, blinds closed so it’s pretty dark in the room…. you can see behind the elk on the clock that there’s a discoloration in the center of the hot spot…
This rather awkward shot at the 1’ square white ceiling tiles (styrofoam, pure white) shows the dark center and some oddity to the color’s in the peripheral… all in all not bad but too similar to the XP-G3 for my tastes.
Sorry, these are on my new iPhone SE, too crippled up to use a real camera and get down on the ground for the ceiling shots.
Someone posted a pic or maybe it was a link, of a nice holster for the d4, can’t seem to find it in this massive thread… It had orangeish stitching and a nice texture material.
Thanks for the reply Geuzzz, but nope, Manker holster doesn’t have all the orangish stitching. Thought I saved its link somewhere, but can’t find it for the life of me, beautiful holster it was….
Ok, so now my D4 is equipped with the XP-G2’s that I removed from my DQG x7 XP-G2 light. They’re a bit on the warm side, not bad, slightly more so than the 319’s.
Edit: Bangood doesn’t stipulate further than NW, so these are probably in the 4000K range tint wise, pretty warm for me.
