FWIW, the standby delay is fixed in my new code project.
If I understand correctly, the delay was there to allow for handling of trailing input events, to make sure the LED was off and the switch wasn’t still pressed. But that’s all automatic now so it doesn’t need to wait.
Changing the angle of the LEDs eliminates the square corona produced by the Carclo optic. I’ve tried XPG2, XPL HI, and Nichia 219C with both boards and confirm that Richard’s offset star produces a better looking corona with all three.
The Mtn board doesn’t completely eliminate artifacts or weird corona shape… but it does help rather a lot. It basically gives you 16 dim flower petals instead of 4 bright ones.
Yes, it’s stating an opinion or a small fact that may or may not make a difference for people to know, so, for what it’s worth, think about this….(FWIW)
Like, FWIW, this light has double o-rings on both ends of the battery tube. That may or may not matter to anybody, but there it is. (again, “this light” being just something I pulled out of the blue not necessarily meaning the D4.)
Pretty close, “For What It’s Worth” is usually more a slight correction about the facts rather than an opinion. As above, TK was simply pointing out that her new code has fixed what might be considered a bug in the code. It does not change how lights already released to the wild will behave (unless they are re-flashed).
IMO - The D4 is the greatest flashlight of all time, OF ALL TIME!
FWIW - US buyers will get a D4 sooner if they order from MTNElectronics rather than International Outdoor due to shipping times.
I just changed my grey 219c mcpcb for a XP-G2 S4 5D 4000k. Wow, what a fantastic tint! Very warm with a nice subtle rosiness. It is everything I had hoped the S4 3D would have. Definitely my favorite now.
Now I just need to reflow some 219c 90+ CRI, r9050, sm405, d240 on another mcpcb
And after that I need to buy another one with XP-L Hi 5000k and another one to try dedomed XP-G2 S4 2Bs or S2 1D in it. In the end I’ll probably end up with 5-6 D4s :person_facepalming:
This solar force clip works after removing some material from the interior of the ring.
I’ll need to grind off the unfortunately placed lanyard ring. Would’ve been better at 90° to the clip.
Oh yeah, the light doesn’t work with the clip on. I’ll need to either remove some stock from the cap or put a magnet under the board in the cap. Not sure if that board comes off easy so probably off the end of the cap. $10 off Fleabay.
Something going on with tinypic and can’t get flickr to embed. here’s a link.
Another solution to make the light work while there’s a ring between the tube and tailcap is to add some wire in the tailcap. A paperclip can work, or copper wire if you have it.
embedding images really isn’t difficult, the biggest concern really is having a stable online storage point. Then easy access through good internet. And the ability to search fast, through key words or fast typing skills. Or a green magic wand…
Not sure where this clip originated, it was in my kit…
Placed an order for a green nichia D4 thru Int Outdoor. How long to the U.S. Is the shipping? I’m not in a huge hurry, I got the fabulous astrolux s42 to play with! WTF were they thinking?
I really don’t know Gunga, it’s a nice fit and the ramp at the end of the clip mates up nice with the head, but if you don’t hold it out slightly when removing the tube from the head for a battery change it’ll scratch the head. (Of course, the tail cap is also removable)
I’ll be going to a shorty tube as soon as it arrives…
