nice thanks
no fan?
Sorry my bad English, please, explain a little the question.
there is no ventilator behind those holes?
I’m pretty sure there isnt. Active cooling would be a whole other animal plus it would require pathways for cool air to enter and hot air to escape. This light doesn’t have that. It looks like it just let’s air in to expose more of the internal heatsink.
I’m still not sure if they kept the plate design heatsink from the video. Promo pictures show a different design.
Not. There is not ventilador. Combine step down, electronic thermal control, and air circulation. Im happy whit his thermal performance. I do not publish this data because can be very different whit the News modifications
Thanks
Can’t imagine it helps a great deal with those tiny holes
If you get the new head, could you use a piece of aluminium foil to close them and see if it makes a difference?
I’ve one last question:
We have seen the maximum output in your great review.
How long was the light running on the highest level, until it stepped down?
Turbo similar to spec, high a little less.
In these two cases, the differences with the specified may be related to the thermal control system. When the flashlight reached 70ºC (external), I turned on the ventilation, the temperature down, and the power up.
This is reflected very well in the graphs, but I do not want to put some data that will vary appreciably after the head modification.
The real problems of runtime come in other modes, as they are much more powerful than specified, so the runtime is greatly reduced.
You can make all the question that you want
Ok. I will do it.
Always turn on ventilation around the outside 70 degrees. We can check the difference in time to reach that temperature and how the light flux is modified
What do you mean when you say you “Turn on the ventilation”?
Are you saying you have a fan nearby that you turn on to blow air across the light to help cool it?
In the integrated Sphere. The test begin whithout ventilation. When the flashlight reach to external 70 degree, then i cool in
How do you cool it?
When will they send you back the head of the light?I see restocking is in September 30 at BG’s site plus they allow pre-orders.
If there was the full review,and was positive,it could be possible to buy one with a coupon.But I don’t know if the coupons are valid till the full review is uploaded. :person_facepalming:
Nice man, looked at your other reviews too and dang I understand why they send you top notch lights, what nice pics and depth in review!
Looking forward to your results in how much those holes make a difference, we can talk aboit it (I really think it hardly makes a difference) but a real test goes way beyond that.
Two computer fans, powered by a power supply. I can apply the air directly over the flashlight, cooling it quickly, or I can turn the fans and draw warm air around the flashlight. This second is slower, but may come in handy to analyze electronic temperature control systems.
I don’t know nothing about when its back……
I think it’s just a way for them to increase the surface area of the light, just like with external fins. Except that they can have maybe double the surface area without making the exterior fins too bulky and large in diameter. It’s just improved packaging.
The most current pics show a heatsink similar to this, but with a bigger diameter center and shorter fins.
You can see it here.
The plate style may have been too costly to implement, but it would allow air to enter one side, go all the way through and exit the other side. This particular design needs air to go in and back out the same vent holes. Not as good.
It would be nice to confirm this design, though.
As a reminder, here is the earlier design with the stacked plates.
yeah and it looks cool, but without a way for air to actually pass it IMHO and in my estimation, no real benefit, so nice it can be tested when the new head arrives!
