Like Hikelite said it works fine. I was wrong. You won't loose the head, if you are not use 10440s.
All in all. Thanks.
I really wonder why the light doesn't go off when fully tighten on 10440s, like on alkalines. Maybe it's a way of annoying the user not to use them, a warning that they should not be used? I'm wondering all these because the light seems to have been built with some thought, I mean the full tightening for off is really nice to keep the head away from any possible issues.
I agree. Maybe i'm not able to get it off with 10440s ;) I tried it several times. It won't work.
Just this minute I checked it with four different 10440s - same result. The light only turn off with Alkalines, L92 or Eneloops.
Good to know. I'm planning on using eneloops anyway, just thought 10440's was a bonus feature. If I need more than a hundred lumens, I do have other flashlights, afterall.....
I'll keep going with using 10440s. Its not so bad if i can't tighten it off this way. I will report if the light is broken
Thanks for the answers everyone!
I wasn't aware either that it can work on 10440.
You insert the battery with the positive end first, so the negative end is on the emitter side. You fully tighten head to turn the light off, you slight loosen the head and you have high, then you loosen it slightly more and you have low. I really like that it starts in High and it only has 2 modes. Twisting too much to get 3 modes wasn't on my liking when I had the ITP A3. I gave the ITP A3 (R5) as a gift to a friend.
If you leave it untwisted for off so that the first mode that comes on is low is the head too loose to hang out in a pocket without falling off? And I should probably wait a few days to order right, what with CNY and all.
IOS home page pretty much says they won't be shipping until after 1/31, but you can place the order anytime.
Damn, like it a lot, but already ordered Lumintop :~ Reminds me Nitecore D11 :P but in AAA size :) Beamshots/comparison?
PS: the only thing I don't like much: not MED - HI order :| 20 - 100 lm would be super.
The UI is exactly the same as in DQG I.
The reason, why it doesn't turn off on li-ion is probably higher voltage. The switching off mechanism is based on electronic circuit, not typical, mechanical brake of the current path. I wonder, what is parasitic drain when off. Because with this method of switching off, there must be some.
the worm is a serious torch with serious built quality. not much you can do with it. Med, High. that's it. no playing around.
with iTP A3 and Tank E09 you get 6 modes (3 modes with Eneloop, 3 modes with 10440) and can buy protected liion's and unprotected liion's.
brightness is exciting. 7hrs runtimes arent.
please dont be mad with me amigo if you find the worm beautiful but boring. it's not a laetitia casta. :bigsmile:
Haha :bigsmile: I don't say that I don't like Lumintop :P Quite the contrary. But right now I don't need more AAA lights, thats why :~
Anyway, will include this one in my "wish list" :bigsmile: Any review, runtimes out there?
PS: coolperl, thanks for the info and your thoughts about "switch". Parasitic drain was the only thing that pulled me off on buying Nitecore :|
anyone with additional photos of the hole?
looks like a biggish hole with thin wall thickness.
i guess you guys dont care. me either.
just wanted to point out that this would have been a turn off (deal-breaker) if i had this torch on my candidates list when there was still enough pocket money to spend on keychain torches. at that time i decided for the Klarus MIX6 from DD. with KREISHILL coupon codes.
nice torch you have, thanks!!
HD photos .. i love that :beer:
Np :) The wall at this point is very thin, but for me it seems sturdy. Nonetheless it is the weakest point. I don't using my aaa lights with a keychain, so I'm beyond danger... ;)
After 2 weeks of shipping, recieved my precious purchase ...
My Opinion ?
Should be better knownd, because it is cheap,well built,bright, small perfect EDC ...
I would prefered a clickie like the tank007 tk703, but the tk703 is single mode ! the SP11 as a perfect low mode ...
note : 9/10 !
Welcome to BLF, hugo-carlito! I ordered my SP11 on 1/29, shipped on 2/02, so it should be here soon.
Please post some pictures if you can, and be sure to post a note in the Introduce Yourself sub-forum to get a proper BLF welcome.
…I would prefered a clickie like the tank007 tk703, but the tk703 is single mode ! the SP11 as a perfect low mode …
note : 9/10 !
Salut et bienvenue au BLF !!!
I will put picture ASAP
j'ai encore du mal avec les photos ...
