Interested
MATEMINCO release MF-02 final production photos. Very nice looking light!! Iām interested!
Nice
Is there already a Mateminco version of the Astrolux MF02 already released (like the MT18 was released before the MF01)?
Or are they still working on the design?
For the group buy the LED is CW or NW ?
nice. :+1:
Interested ā¦ depending on modes (if thereās a low mode for edc use) and if it takes protected batteries.
Interested if NW option will be available.
Mode will be same as MF-01. Protected cells are going to limit its output.
Interested
ĀæSame modes? ĀæSame UI?
Can we assume this data from the MF01 for the MF02?
āLow, Medium, Medium1, High, Turbo + Strobe, SOS, Location Beacon
One single switch provides access to all functions
Ā·5 brightness levels and 3 special functions available
.Light off or Normal mode, click twice to enter turbo or click three times to enter tactical strobe
.High efficiency constant current circuit, Reverse polarity protection
.Direct thermal path(DTP) copper board
.Intelligent temperature control,over 60 degrees will reduce the power and output will stablilize in about 2500 lumens
.Breathing light and lockout design
.Breathing light displays battery voltage
.Integration and high efficiency optical lens
Ā·Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish
Ā·HAIII hard anodising
.Standard 1/4 inch Tripod mount
Ā·Waterproof in accordance with IPX7
Ā·Tail standā
For XHP35 Vf at 2500mA is close to 4 x 18650 in 4S, like BLF Giga Thrower.
I think 2S2P driver is the best solution.
Does anyone have an idea what the GB price would be?
The MF-02 has a ābitā more emitters so Iām guessing with the bigger case it would be roundabout the same price?
Interested
Interested.
I was told that MF-02 group buy price will most likely be set close to MF-01. [image] Although MF-02 has much lesser LEDs than MF-01, they have to factor in higher raw material cost, longer machining time, and higher shipping charges (size & weight). Some figures for quick comparison: ASTROLUX MF-02 CREE XHP35 HI 2500lm 1.5km+ - $68 (to be confirmed) BLF-Lumintop GT with higher KCd - $111+ Manker MK35 XHP35 HI 2550lm 1420m - $155.95 Klarus G35 XHP35 HI D4 2000lm 1000m - $98.98 Thruniteā¦
Since there is a preproduction sample - when will we able to get some beamshots?
Interested
What are you expecting from a beam shot? Itās the same basic flashlight design as many other lights. I would guess the beam pattern is going to look exactly like any of those others.
So - why do manufarcturers make new flashlights when they are basically all the same?
And Iām pretty sure that the beam would be a bit different from a S2+ or soā¦
I want to see if the beam is nicely round - I only have 1 XHP35 Flashlight (Haikelite MT02) and that beam is ugly
Im very interested, please add me to the List
