How ?
Thicker aluminum shelf, thicker MCPCB ? Both ?
In-charge for MF-01 project has already read your ticket/ email today. You should receive a reply from him or his assistant soon.
Tiny 26650 III has slight hint of green.
Yes, I know. I have one. It’s a bit on the neutral side, hint of yellow, with a little bit of green. I was wondering how the xp-g3 used in this MF01 compared. If it’s the same, I won’t like it. If it’s a bit whiter, then I would.
I`m so pleased with my XPG3 that I`m also thinking about getting 219C version.
By the way how is that MF-02 Thrower deal going,any news?
We touched on MF-01 battery carrier issue and customers' feedback, HaikeLite production, and some other upcoming group buys today. Not in the hurry to roll out MF-02 yet.
I may have missed discussions about those upcoming groupbuys and HaikeLite production.
I was under impression that MF-02 GB was set to happen next month.
Based on Silicoon pics, i suspect MF-01 XP-G3 tint will be fairly close to S41S version. You are right, DQG is more yellow than green, i remembered wrongly.
interested XPG3
Not on mine which works fine but, could a short occur here (to much solder on the resistor or if the resistor is touching the aluminum shoulder in the head) ?
It’s probably already connected , seems to be the same trace… So , it seems to be alright.
Emisar D4 nichia // MF-01 nichia
My MF01 219C is clearly more warm than the S42 XPG3 :
I love so much the MTG2 it is really good for daily use the tint is perfect. MF01 is more warm than MT03 and others from left :
i can see a purple tint on MF01 spill….but my eye doesnt see it.
my EOS7D does
Indicate your LED choice (XPG3 / 219C) in you reply if possible.
Edit your previous post instead of creating a new request.
Notification List
Updated on Sep 20, 2017
- andrewmac
- danggitbai
- Kingjohn
- cheesecheeks
- Sergeantrecrut
- cyropro
- heatwaves
- Lou_Menn
- Robsva96 - XPG3
- Dralf
- Nicolicous
- Phantom1
- ramptosd
- laythaws
- BeardedRaleigh - 219C
- Sukoi
- Wieselflinkpro - XPG3
- gastonpatagonico -219C
- sammubara
- qandeel - 219C
- Ilmatic - 219C
- tantrik77 - 219C
- watamu - 219C
- rafalklis - 219C
- CJ Avlis - 219C
- jamaya - 219C
- Mr.Beam - 219C
- Mr.Beam - 219C
- maildroid - XPG3
- Wolpi - XPG3
- andrewmac XPG3
- southland - 219C
- xxx - XPG3
- mrheosuper - XPG3
- atbglenn
- Nicolicous - XPG3
- FG1 - 219C
- ersecu - XPG3
- xdouang - XPG3
- thommy - XPG3
- Itsme
- sammubara
- Lou_Menn
Notification List
andrewmac
danggitbai
Kingjohn
cheesecheeks
Sergeantrecrut
cyropro
heatwaves
Lou_Menn
Robsva96 - XPG3
Dralf
Nicolicous
Phantom1
ramptosd
laythaws
Sukoi
gastonpatagonico –219C
sammubara
qandeel - 219C
Ilmatic - 219C
tantrik77 - 219C
watamu - 219C
rafalklis - 219C
CJ Avlis - 219C
jamaya - 219C
Mr.Beam - 219C
Mr.Beam - 219C
maildroid - XPG3
Wolpi - XPG3
andrewmac XPG3
southland - 219C
xxx - XPG3
mrheosuper - XPG3
atbglenn
Nicolicous - XPG3
FG1 - 219C
ersecu - XPG3
xdouang - XPG3
thommy - XPG3
Itsme
sammubara
Lou_Menn
I’d like to change my selection to XPG3 please. Sorry for the inconvenience.
Okay, your guy who’s light went turbo on one bank when power was connected. I had to look it up because I can’t remember.
Do you want to take the light apart and look around, wiggle some wires? I was thinking one of the 3 drivers had a short to ground. Just taking the driver out and poking around might fix it. If not, then it’s definetly a warranty issue. Make a video for them. It’s not a battery carrier issue.
I actually did remove the screws to the brass ring and board, just to have a look. The wires to the board seemed secure. I could not tell if the wires were damaged at the center hole, without desoldering them from the board. I have almost no experience with soldering, especially on circuit boards, so I did not attempt anything and put everything back together.
Thank you for the update, Freeme! I’ll be looking for their response.
17track:
2017-09-12 15:22 Item is announced /bppost received the information
then it vanished as “not found”, after few days I got this:
2017-09-12 10:04 Item is announced /bppost received the information
now it vanished again…
PackageRadar:
September 18 14:03
Electronic shipment information received
Belgium Post
September 18 10:04
Belgium Post
17track:
now it vanished again…PackageRadar:
September 18 14:03
Belgium Post
September 18 10:04
Belgium Post
Same here. Looks like plane flew over Bermuda triangle…
How does this work? You make a deal with banggood and we order it?
Just for info that TA Narsil board used in TLF was designed from me lately
that MF01 design is on sale in the 4. batch just I wait for 3 orders, then order 3 boards, as the PCB is not cheap ordered from Oshpark
