That's weird - maybe they used a little dab of glue because of that stubby screw. Might want to try prying with a hook tool, or something similar but careful not to damage threads. What I'd do is thread the 2 screws back in partially, so only in the PCB, then grab onto one with a small pliers and try pulling it up.
The driver can be pulled out some with just the two driver screws removed? The driver wasn’t stuck at all, moved freely with the screws removed, I just thought I needed to get the button switch screw/cover off.
Edit: was able to pull out the driver, was fairly clean, put it all back together and not touching it anymore. No want to break it
First of all, a big thank you for the Q8 team that made this all possible, it’s a very nice flashlight, i really like the ramping mode on it, and it has a nice and decent feel to it. And although i only got 2 battery’s at the moment (new one’s are still to arrive), is produces a lot of light
I have been a (very) silent member, i read the most part of the Q8 tread here non the less. I received all the three Q8’s i did order, relating to the problems people have i can report:
- 2 of the flashlights don’t have equal lighting in the switch, the last one is fine
- also the three lights here have a “dirty” copper ring, but we can clean this, no problem
- One light has a very small dent, bearably visible (sorry for the photo quality, don’t have a decent camera available here at the moment)
- One has a small “dent” inside
Here you can also see a little bit of dust other people are talking about, i wiped the top clean with my finger, but there is a lot of dust left. I think i am going to disassemble them to get them clean.
- Although all three got dents in the rear inside part, when the springs are
I don’t really see them as a problem, dents are on the inside, and are not likely to cause any problems. Just to point at some point’s where possible improvement is possible for the future. Although i am very interested to know what is causing the problem with the switch lights. If there is a solution to this problem i would be happy to order a spare part or pcb to replace them, even if it would cost a few dollars. It would also be nice if they would dim a little bit more, they are quite shiny. Maybe i will look into it some more, i replace them myself (soldering a led of resistor is not a real problem for me), only i don’t have the knowledge to see out the parts i need.
This weekend friend of mine will pick up his Q8 i did order for him, i think he is also going to be very happy :laughing:
Thanks again Q8 team! I’m going to try to be more active here (although i live a very busy life), and i will certainly report any problems may they come up
Today i received my Q8 (free shipping option) and this is how the package came out of the typical grey plastic Banggood bag
So i could not wait to try it, so put some new and fullly charged 30Q’s in it and i noticed the unbalanced switch indicator LED’s.
Then played a little while with it, and man, i love it! I love the ramping, love the size, love the tint, it’s a winner!
Luckily the indicator LEDs do not show any signs of intermittent flickering or such.
One thing that annoyed me is that i did not notice a small burr on the end that touches the head on the PCB, which resulted in a scratch on the PCB (poor picture)
Even my wife, (who thinks i already own too much lights) said it is a nice light, well thats a compliment for her
Nice!
Great news finally a real production Q8 in the hands of another team member! Awesome for we all know Djozz has no problem saying how it is.
Sorry, very good to go into the weekend with others being positive and nice too of course, but joy not all the weight of answering about production Q8 lights is on Toms shoulders!
Cheers all poured myself a drink 50% red fruit syrop and 50% decent Cognac to celebrate, cheers
Good weekend all!
I purchased three Q8’s and 2/3 had this black stuff on the ring. There wasn’t much but it was noticeable, almost made it look like there was impurities in the copper – Isopropyl alcohol barely did anything to remove it.
I ended up using Acetone and cotton swabs and I had to scrub quite vigorously to get it off, it was amazing seeing how dirty the acetone swab was when I had cleaned it with isopropyl seconds before and the isopropyl swab came off clean.
I managed to get almost 100% of it off, but I feel like after putting my lights back together and using them that a small amount came back, I’m starting to believe it’s part of the button tops rubbing on the copper and leaving metal there.
Maybe they were dirty from Thorfire testing the lights with 18650s before shipping? Maybe Thorfire is using 18650s with crappy quality button tops or solder blobs?
Now copper should be softer than whatever the button tops are made of, but maybe the button tops are nickel plated or something? Plus solder is definitely soft enough to be affected by copper.
EDIT: The ring is brass not copper, duh me. I honestly thought it might have been brass considering the color, but I figured it was copper due to its better conductivity. Brass is only 28% as conductive as copper, but copper oxidizes… man if only we could have silver plated copper lol.
With both of my today arrived lights I only got around 4000 Lumens with Samsung 30Q Solder-Top and Protected Imalent from the DT70. Is there something wrong with them?
Or is my lightbox badly adjusted? But I got similar readings on the BLF A6 compared to what was written here and similar readings here and on TLF with the Astrolux MF-01 Nichia.
The ring is brass not copper, but doesn't explain anything, don't think. Hhmm, I'll have to check the ones I got - maybe didn't notice/look for it. I'd probably use some 600 GRIT paper on them if the isop. alcohol didn't work. Maybe just not cleaned up from the manu process.
The dark smear could come from the contact ring, or it could be carried on whatever cutting tool they used (maybe it’s scorched lubricant?)
There are a lot of different brass alloys. If it’s a “free cutting brass” alloy, containing lead, the lead will smear out across the surface under contact — it’s a feature lubricating the cutters.
If that’s the source of the dark mark, a combination of vinegar and hydrogen peroxide will clean the surface: http://brewingrabble.com/resources/surface-lead.htm
Interesting data point: on my previously bad/flickering switch board i replaced the resistor and both LEDs (same reel, should be same properties) and one of them was still dimmer than the other. I’m thinking now that it is due to the traces in the board itself rather than the LEDs being mismatched.
Are there any oshpark board designs or there I can try as a replacement for this illuminated switch?
TheMiller posted somewhere in here, or the Q8 mod thread (moving so fast it’s hard to find), that Thorfire is redesigning the switch board. I would imagine, they would offer you one when it’s complete.
I would take you up on that bet The Miller, sadly my flashlight spending money is tied up at the moment. Have a good weekend, I am sure this whole situation has a lot for you to deal with. I’ll do my best not bother you with further apparently unanswerable questions . It is what it is and you deserve a break
traces cant be the issue, just 1 resistor for both means even the slightest difference in Vf makes on dimmer
Cree LEDs of the same reel usually have quite the same Vf,
but for those tiny SMD LEDs the emitting area is a lot smaller, so they may vary a lot more
Unsoldered LEDs and switch just holding my temp stabilized iron at 300°C at the other side
also skillet might work well
With solder blobed 30Qs you should definitely get 6k+ out of the box.
Either your reading is off or your batteries are not fully charged or both your lights are under performing - but that seems a lot.
Try tightening both ends of the flashlights and see if it gets better. Some clean up could help too, according to reports. Seems odd that the two lights are both so low…
