My second Q8 arrived today.
It does have the mismatched SW LED’s when sitting in standby state, unlike the first one.
It has an intermittent problem.
It will sometimes not shut off.
The first time I turned it on, I ran it up the ramping about half ways. Released the SW and immediately ramped it down to ML. Ran it back up and down a couple or so times. Then hit the SW to turn it off. It stayed on. I hot the SW again. Nothing. I untwisted the body from the head a quarter turn and it went off. Of Course it would.
Turned on. Turned off. that time all was okay. Since then I have done many of the tricks it is capable of; battery level check, OK. Four click lock out and back in, OK. Double click to jump to turbo, OK. I let it run on turbo to check the timeout; 3 minutes, so OK.
A couple of times during these trials it would not turn off. Clicking the SW caused the SW LED to flash, but the light remained on. Sometimes after several clicks it would go off. Sometimes I would give up after a half dozen clicks and turn it off by loosening the body to head.
Sometimes, when it will not turn off the LED’s will flash and be very slightly brighter, then with the next click go back down. This is with the light on ML.
I attempted to make a video. Naturally the light worked fine during that time. I’ll try again later. I have both lights with 30Q’s, one in left hand, one in the right hand, clicking in unison. The good light, #1, works flawlessly but #2 hiccups every so often.
Sure would like #2 to work reliably.
