Hello!
I am actually looking into several lights and I found a very great deal on Haikelite MT03 and I already pulled the trigger on it lol
10LM,150LM,1000LM is a usable and good light spacing for me, and get to kill zombies with 9000s so that one I got (But haven’t arrived yet…)
At first I was looking at Imalent lights but the one I interested in had bad lighting spacing (from too low to too high) so I scratched that off the list.
Another I very considering is the Klarus G20… 3000 lumens max (Or so they claimed) Rechargeable and comes with battery ready to play. Also found a very good price just under $65 new…
Reason I want this MF01 is because of that high lumens output with under $100… I know it won’t be able to run in turbo for very long but I still want it for no real reasons…… but bright lol
To be honest I do not know how long “my fix” will last on the carrier. The entire brass button assembly seems terribly weak and if you change batteries often without checking if there is full contact on the board, it may loosen without you knowing it (not everybody have a DMM) and then you are “buring” batteries. The whole soldering process reminds me of my black and white TV that I had in the late 70’s. You just looked at it, and the wires came loose. (Cold soldering.)
(So yes freeme, if the first batch buyers can get hand on an upgraded carrier I will feel much happier both for myself and all others.)
QUESTION: Anybody willing to let me borrow one of these to compare with some other lights in a video? I can pay a deposit and shipping costs both ways etc?
Alright guys tell me how does this work? I post which model I want and they will reserved a light for me? or how does this work.
If anything… I’m leaning the Nichia 219C…
500 lumens difference between XP-G3 and Nichia is probably almost not noticeable to eyes….? Saw a few video reviews I can’t really tell the difference between the 2… Both look great to me… But after reading 47 pages on here… I saw lots of people choose the Nichia for it’s CRI and the tint. So I think I’ll do that too lol
The price increase of MF01 V2 is considered to be due to the holster attachment.
Since it is attached to MF02, it is not strange even if it is attached.
Let’s expect
In your report XP-G3 seems to be almost 12000lm,if 219C it is about 10000lm.
Even if you compare both, the difference in degree can be seen.Also, fever and color are different.
Yes. To keep the white disc in place, it was not glued but retained by the brass button that has a “T” shape. The larger upper part of the brass button keeps the white disc in place.
So they have to put the disc first and then solder the brass button. I suppose that they heat the brass button quickly to not burn the white disc, this resulting in cold joint and/or brass button not fully soldered down to the MCPCB for optimized contact.
After removing the white discs on my MF-01, the 4 brass buttons were sitting “higher” than the MCPCB, one with little solder under it.
