Interesting Pilot. You are so right about the heat sinking fins on lights. For bike lights, they usually face front to back so air is flowing over them. As a matter of fact, most bike lights get quite hot standing still because they were designed with air flow in mind. Here's an example you might find interesting. Troute started as a DIY guy.
wow
thermal analysis, and to an extent that very few, if any, manufactured lights get
that is one squared away flashaholic!
That is quite an impressive project!
Can you give us a list of software you used for this?
That's ok. It was just a picture of my old trail Jeep (XJ). But yeah, keep us posted if you do decide to make them for sale. I've been holding off installing any aux lights because nothing really struck my fancy. This looks like a winner!
Nice, thumbs up for figuring out the cooling!
Some serious driving, 24 XM-L´s at 3A :o
At least I would be satisfied even with a little less of current with that amount of emitters :D
Wow.
I wish there more threads like this. 24 XM-Ls . . . farking awesome.
farkFoy
Really great :)
Cant wait for the result!
Fritz
wow
Sorry I've been gone for a while - Life got busy, as life tends to do once in a while..
dthrckt, Thanks very much for the 'wow' :) Thermal Analysis is quite amazing today - My suspicion is that the big guys don't do it because they don't want to know :)
The Solid Modeling was done with SolidWorks 2011
Thermal Analysis was done with Solidworks Flow Simulation 2011.
CNC CAM was done with Mastercam X4.
Circuit board Schematic Design was done with Orcad Capture CIS
Circuit board Layout/Route was done with Cadence Allegro 16.3
More to come!
PPtk
Had a few minutes the other day, so I threw together a schematic and layout for the circuit board that will carry the LED's and the drivers. I may consider sharing this once it's been debugged and proven to work.
Here's what went out to be fabricated. Should have it back in three or four days.
Overall, the board has 1,678 vias - the vast majority of which are strictly for helping move heat away from the LED emitters and into the enclosure.
The board was designed for 30 Amps of current (Max current with 24 LEDS at 3A each is about 20 Amps) with less than 0.05V of drop across the 14 inch length. Each group of 3 LEDs will be infinitely and independently variable in brightness. PWM Frequency of the constant current drivers will be 500 KHz, so there will be NO audible hum or visible blink. With the particular N-Channel MOSFETs and ultra-fast recovery Schottkys that I've picked, efficiency of the driver should be 92.. maybe 93 percent. Not bad..
PPtk
Circuit boards showed up yesterday. They look great. I'll be putting parts on and testing the circuits this week - should be making light by next weeekend.
The enclosure goes monday to be anodized.
2ish weeks and I should have a fully completed light!
Man, that's lookin' bad ass.
Pilot -
This project is so awesome . . . I can't wait to see this on the front of your Jeep. Regarding throw; would you say each triple approximates say, a Dry or Sky Ray in size/reflector depth/configuration. Will it be, basically 18 Drys and 6 triple XP-Gs driven to within an inch of their collective lives?
Sorry if I missd it . . .
Foy
Impressive. I'm really looking forward to this thing completed. :)
Absolutely brilliant project, looking forward tot his perhaps becoming available as a kit.
Awesome work! Did you learn or study something related to this?
wow you are a perfectionist also a dedicated board
but hey lazy ass you promised 2/3 weeks! ...kidding xD
Pilot -
Foy
Foy,
Thanks very much for the kind words. I'm happy that you are enjoying my project.
The optics are a LITTLE smaller than the SkyRay/TrustFire/DRY - but they're TIR, not reflectors. In my limited experimentation with them, the beam profile is quite similar to my trustfire 3-XML. The hot spot is beautiful and is hard to even define - it just rolls off into very useful spill.
I believe the Trustfire and the Skyray are actually driven less hard than I will be driving my emitters. I'm giving them TRUE current-controled 3A each. I'm not sure how hard the DRY is driven, but I think I recall it having a Direct-Drive mode where it's probably getting more than 3A per emitter.
For the moment, I'm going to populate the board with all XM-Ls (24 of them), as I don't believe I'm going to need the additional throw from a few XP-Gs. There will just be so much light coming out the front of this thing that I don't believe its going to matter, and I'd rather have the raw lumens of the XM-L's than the slight increase in throw from the XP-G's with the resulting fewer total lumens. I'm also more confident that I can get the tint to match using all the same emitter type.
PPtk
I still haven't made my mind up about this.. Depending on how it all comes together, I may sell the completed units. I'd probably be willing to sell it as a kit as well, but frankly, it would be really difficult for most people to put together at home. The circuit board uses QFN parts.. 0603 parts.. and even the emitters aren't easy to solder. I solder QFN parts by hand all the time, but I've been doing this for a long time - a hobbiest doesn't stand much of a chance of soldering a QFN..
What I might consider is selling the circuit board with all the parts already on it as part of a 'kit'.. The only problem with that is that the unit is 90% built at that point.. kind of defeats the purpose of the word 'kit'.. Still pondering..
PPtk
THANK YOU!
I'm an electrical engineer, and all of us EE's are forced to be mechanical engineers whether we want to or not..
PPtk
Oh, I'm far from a perfectionist... Too many years of getting things done, not getting things perfect. Perfect comes at the cost of time - not a luxury I usually have.. I always strive for 'as close to perfect as I can get in a reasonable time period'. Thank you though, I'm proud of my project - perfect or not.
I only wish it was me being lazy that has held this project up a bit. I can't tell you how much I'd like to sit on a beach with a Johnny Walker Blue and have people point and call me lazy :) Unfortunately, what has held this project up has been work - I've been absolutely buried the past month or so.
It's coming though - results soon!
PPtk
