Thank you. Looks great
Maybe I killed it because I used LG HG2…
If using high drain cells, you may try lowering the cell voltage. You could, for example, start at 3.7V with a 30Q and measure current flow. Maybe the overall Vf off 3 XP-G3 emitters in parallel is a bit low, this way there's a very good chance the emitters will survive by limiting the potential current avalanche.
This looks maybe like design fail and if it is it needs to change.
No battery should cause leds to die in any flashlight.
That is what regulated drivers are for.
Cheers :-)
I guess you are right
Turning blue means catastrophic levels of current being pushed through the chip.
I had a “3V-22V” drop-in that I wanted to test to make sure it could handle even only 2 cells, so put in 2 18350s. Got really blue and really dim. Didn’t have it that way for more than 1-2sec tops, pulled the plug. 1 cell back in, the bugger survived.
1 cell?? Dunno how a trip could go blue from only 1 cell like that, even if just crowbarred right across the LEDs.
Unless they separated from the mcpcb and were just floating? Could make electrical contact w/o much thermal contact. That might cook ’em.
It was on no more than a second after turning blue but no help. I don’t understand how would they get so hot that fast. I was using it max 2 minutes before they died but it wasn’t constant on as I was playing with modes.
Interesting is moon didn’t work at all (before it died), leds were off in that mode.
It’s before my time here, but I believe OL did pretty much only DD lights: LED and Li cell and switch, that’s the whole circuit. Don’t think they could cook so fast unless there was some serious thermal upset.
’Though now with continuous-38A cells…
Turning blue means that solder under led is bad and melting at low temperatures. Try to reflow same xpg3 with better solder and flux, worked for me couple times even with DTP boards and XHP70…
You think they could work again?
I did led reflow only one time before, so no experience with that and no tools for that.
I am 99% sure they will come back to life…
Probaj nemas sta da izgubis
So runtime is less than 30 mins on high? And only 13 kcd?
NikolaS
I will try
blueb8llz
That’s what manual says. I have no way of measuring it.
The emitter board is said to be aluminium and heat transfer to the leds' thermal pad is thus also crippled. It would be wise to start measuring tailcap currents with less than fully charged batteries and work your way up from there to observe current ramp up as cell voltage is increased.
As it is, lower discharge cells may work better in this torch.
Cheers
You were right, reflow helped and leds are working good.
Only problem I have is it died again, but if I press on led with my finger it works when pressing.
I have to clean the board and replace solder and I think it will be ok. This time I only heated it as it was.
You welcome :sunglasses:
Just clean all remaining solder with copper wire after removing led, and some 1000 grit sandpaper will clean underneath led remains with just slight moving without any pressure. Applying good flux and quality solder will solve the problem for good…
NikolaS
I tried today several times and there is always at least one led not working good.
All of them are working now, but 2 are on only about 50% brightness.
Not gonna bother with it anymore.
I have asked Sofin for replacement MCPCB or I will somehow put 3 DTP boards in with XP-L HI.
Just ordered this light and three of these: http://kaidomain.com/p/S026300.Nichia-219C-Neutral-White-4000K-CRI92-LED-Emitter-with-KDLIGHT-3535-16-16mm-x-1_5mm-DTP-Copper-MCPCB
Since I have these LEDs as a triple in my S2+ and I am loving it, I hoipe to get a very nice High-CRI trower (i.e. more throw than that triple S2+ ;)) with this combination.
Sorry to hear that,hope you will end up with best solution. I have xpl-hi on the way, hopefully next week I will have a chance to test out that driver since Sofirn claims 4.5Amp and 1300+ lumens.
I will do a short review also
I am on the same boat, NikolaS. I am waiting for a C8T on its way in the slow boat.
Cheers :-)
