Iām back sooner than I thought I would be. Now to some hitherto undisclosed details. There will be an integral charger, a TP4056 board. That is what the previously shown rectangular cutout in the side is for. However the USB socket is mounted remotelyā¦
This is for the USB inlet port. The grooves adjacent to the left is where I was first going to place it. But I changed my mind.
More parts. One is store bought and was retrieved from my box of miscellaneous metal odds ānā ends. Stuff that was intended for some other previous project or just ācollectedā because it was cool. That one is about 1 x 1.5 inches and from 0.040ā (1 mm) copper sheet. I needed one a little larger so traced the store bought onto my 0.025ā copper.
I cut it out with av snips.
Then, clamped between wood blocks, I filed it to refine the shape and smooth the edges.
Store bought on the left, my handcrafted one on the right. Iāll press that oops out.
Originally my plan was to use the larger one by itself. However, stacking the two is more attractive to my eye.
Holes drilled for mountingā¦ #2 x 1/2ā brass screws.
Thatās all for today. Hopefully Iāll be back tomorrow with more progress. Thanks for looking.
I wired the USB port up to the power in terminals of the TP4056. Some kaptan tape was used to temporarily tape it in place. Then a brass escutcheon pin wasdriven in through one of the unused board connection points to secure the USB port board from pulling out of the block when unplugging a cord. Escutcheon pin = fancy name for a decorative nail. Thatās it in the middle of the 5 holes along the one edge. The pin head will require a slight dimple in the wood cover plate.
After careful measuring the TP4056 was affixed to the copper plate using Arctic Alumina adhesive and some kaptan tape to ensure electrical isolation from the copper plate. Inside the charger board recess, lower left edge, you can see two small greyish looking circles. Those are fiber optics.
Here we have a test underway. The charger is charging. The red light from the LED on the TP4056 board is piped through the fiber optic so we can see a charge cycle is underway. A change of lighting has made the wood appear more red than it really is. The color of the padauk will change over time, as both light and air does cause a shift to darker shades.
Rather than wait for the Samsung cell to reach full charge I changed to a fully charged Panasonic cell. The blue LED light now illuminates to indicate a full charge has been reached. (The charger was previously tested and it does function properly. I was just in a hurry for the photo.)
The charger side, opposite side of where the fiber optics exit. The copper plates are affixed using brass screws. They do multiple duty as access cover for the TP 4056 board and a heat sink.
Thatās it for now. Gotta get back to the shop. Thanks for looking.
The upper left side bore hole, the one with the penny visible in it, is where the 18650 cell is located. Plus end is inserted first. There is a spring at the bottom end, the + end and another spring soldered to the down side of the penny. The short walnut dowel rod fits into the upper end of that bore hole to hold the cell firmly between the + and the - contacts.
The cell is not meant to be removed for charging. The cell can be changed out if that is necessar, by removing the three Phillips head screws that secures the wood back plate, similar in concept to the LiPo that CRX used in his beautifully crafted entry for this years contest. Changing the cell is a bit more involved than with a conventional flashlight with a threaded tail cap but is still less hassle than my laptop or an iPhone.
As things sit right now some of those visible wires are not yet connected. The ends are just pushed into the various nooks and crannies to allow me to trial fit the cell with the connector plates. The walnut plug is long enough to fit the flat top Panasonic 18650B cell. The springs provide sufficient squish room to allow for a button top, maybe a protected cell. I have not tried one. The driver is equipped with LVP so I donāt really feel the need for a protected cell.My plan is to use the flat top as I have a few without homes.
Maybe I can get this done tomorrow. I need to fit the driver and connect it to the MCPCB/emitter, mount the copper emitter plate, complete the wiring and see to a few other details.
Reviewing my original design notes, the first thing on the page is āpractice brazingā. I skipped, never got around to, that step, though I did get some Fuze-CleanFS. The acetylene bottle has been empty for months thoughā¦ keep forgettingā¦
Itās finished!. Hereās the back with the driver installed at the right and all the wiring complete. Kaptan tape used to keep the wires out of the way. I glued a piece of tool drawer liner to the bottom; just visible to the left.
This is it, upside down. The back plate has been installed with the three 8-32 aluminum screws.
A three quarters frontal view, from the brown wood sideā¦
Three quarter frontal view from the orange (padauk) sideā¦
Views with the LED litā¦ There are 6 brightness levels; reverse clicky switch. I did the pictures on either level 1 or 2; I forget. Getting old. :person_facepalming: The 2 x 7135ās (700mA) give plenty of illumination for the intended use. In fact Iāll probably never run it on high. The driver is a Nanjg 101-AK-A1 that came with 4x7135ās. Two of them are now in a parts box.
Looking at a side, say the brown wood side with the copper plates, 4-15/16ā ( 125 mm) wide x 5-9/16ā (140 mm) tall. The block is 2-11/16ā (67 mm) thick. The diameter of the original large hole through the block was 3-1/8ā (80 mm).
