By the way, i got 4x “PKcell” 16340 in yesterday, they seem to hold up fairly well in the M3.
I will try to do some tests later.
These are 2 reviews that analyse the battery. The first one is about the OTR U16, and the second about the M3.
Maybe it was here you’ve seen it?
Also, a quick insight on the battery’s voltage, in their branded charger: ENEDED .
And this post from The Miller about the capacity: Are these OTR M3 runtimes normal? - #7 by The_Miller .
Last week I sent PM to Neal asking about the same thing, about if he sells good 16340’s!
To not overload him with PMs and all that stuff, if you are in contact with him, can you take care of this and them return with some answers, please?
I’d be interested to get some good 16340s and of the OTR is one of the best, and he can arrange some, let’s do it!
Yes, please tell something about those too!
I ordered a 16340 flashlight (Jaxmnve M3, on AliExpress) and wanna buy some cells. But can’t be sure if the PKCell are good or if I should try the Trustfire IMR. So, if you have some insight on those, let us know please
I still use a few aw 16340’s (red ones) not the best but working fine in all of my highish drain 16340 lights.
I received the two Lumintop 16340 batteries purchased from AliExpress as well a couple of days ago. Will pop them in my Liitokala Lii-500 charger to check capacity.
That’s great.
When you pop them into your M3, do you visually see a difference in light output between high and turbo?
Okay, so i did a NOR test on my Lii-500 with the 4 PKcells.
They’re all around 700mAh, may improve a little because they were brand new.
The internal resistance guestimate of the Lii-500 are inconsistent wild guesses, so it doesn’t mean too much, but it seems these PKcells are a little better in that regard than Sanyo 14500.
I think these PKcells are similar in performance to their 14500 cells.
My M3 draws 2.28 A on ‘turbo’ (according to my UNI-T clamp meter) with a freshly charged PKcell,
with a ‘half full’ cell (3.6 Volts without load) it’s 2.24 A.
with a 3.5 Volts (without load) cell it’s 2.05 A on the clamp meter.
So this is where it apparently starts to suffer from the sag too much.
I will calculate the internal resistance now, i’ll get back to you with that.
Just remembered the Windyfire brand market its cells by themselves: http://www.windyfire.com/windyfire-imr-16340-600mah-3a-button-2pcs.html
http://www.windyfire.com/windyfire-imr-16340-600mah-37v-3a.html -> In the past you had to ask for a cheap shipping quote. They may still do it for those of you outside of the countries listed in the above link.
Cheers
And the plot thickens
Thanks for the test Jerommel and the heads up on their site Barkuti!
Let’s see if the PkCell and the Lumintop worth a try. It they are nice, why not?
If they are not, Windyfire may be an option…or the Trustfire IMR…or the AWT IMR…or the On The Road :person_facepalming: :person_facepalming:
Okay, i calculated the internal resistance of one of my PKcells, i think i did it right.
The Voltage of the cell was 3.5 V without load.
I put on a load with a 1.35 Ω resistor, giving a Voltage of 3.2 Volts over the resistor, I=U:R so the current was 3.2 V : 1.35 Ω = 2.37 A
Now i can calculate the total resistance. R=U:I so R = 3.5 V : 2.37 A = 1.47 Ω
Subtract the 1.35 Ω from that, so 1.47 - 1.35 = 0.12 Ohm or 120mΩ
When I (current) is 2.3 A (M3 turbo mode) P (power) wasted as heat in the battery is P=I²×R —> I² = 5.29 —> 5.29 × 0.12 Ω = 0.63 Watt heating up the battery, which is nothing to worry about i.m.o.
Anyway, with Ri=120mΩ this is not a high drain cell at all…
PS: The numbers could be off by 15% (or something) due to my equipment.
Unfortunately the batteries got to me first from AliExpress, even though I ordered the OTR M3 from GearBest at least a good few days before the batteries. Hopefully the M3 will turn up next week.
I know nothing about numbers ( :person_facepalming: ) but from your measurements it seems that for lights like the OTR M3, or an Olight S1R, it wouldn’t be a good battery mainly specially to use the brightest levels, right?
Also, theoretically, it would perform worst than - examples - the AWT IMR , the Windyfire IMR, and the Trustfire IMR, (all tested by HKJ), am I correct?
Thanks again for your work and results on this
It will be okay up to 1.5 Amperes or something.
With a linear driver that’s approximately 6 Watts, which is usually around 650 Lumen from an XM-L2 (correct me if i’m wrong, anybody)
Yes, probably.
I had to know myself too.
I guess we should wait for a next generation 16340, similar to the Aspire 18350.
Probably just a matter of time.
Thanks again for your work and results on thisI had to know myself too.
Thanks again for the explanation Jerommel! :+1:
If I understood correctly, they will run “well” except in the highest modes (that are above 600lm in the lights I mentioned)!
Hum, getting a “Aspire IMR 16340” would be pretty nice :sunglasses:
I like small lights (16340 sized), and I don’t have more because I want to have them with decent batteries and that’s being hard to get (maybe I’m too picky about that, I admit)!
BTW, another confirmation that the OTR battery is nice was made by djozz some time ago, here: What did you mod today? - #1213 by djozz
I guess the OTR cell has to be nice when they sell it with a 900 Lumen light.
I got a comment on my Ri test in another thread:
ir goes up as cell is discharged.
I did not know this, so i will repeat the test at 4.0 Volts and on 3.7 Volts (without load) and see what it does.
Yes, the IR is supposed to be measured on a fully charged cell.
Sorry fellows but, after observing lots of li-ion cell discharge curves:
- When a cell is fully or nearly fully charged and/or nearly discharged the discharge curve slope is higher. Measuring internal resistance when cells are close to full or empty is just wrong.
- When a cell is discharged it heats up proportionally to the square of the current flow. This usually means the cell's internal resistance diminishes a little bit.
- In every other aspect, li-ion cells' internal resistance is fairly constant.
Cheers :-)
Hmm… from the owner’s manual of my Opus charger:
Only fully charged batteries should be tested for internal resistance
I think that however you decide to test, the key is to be consistent and measure all your cells at the same charge/voltage level so that you have apples to apples comparison.
I would say it’s best to measure Ri at the average Voltage, which is 3.7 Volts (without load).
This is in the middle of the range the battery is used in most of the times.
