Review and disassembly: Sofirn C8F
NikolaS
I tried today several times and there is always at least one led not working good.
All of them are working now, but 2 are on only about 50% brightness.
Not gonna bother with it anymore.
I have asked Sofin for replacement MCPCB or I will somehow put 3 DTP boards in with XP-L HI.
Just ordered this light and three of these: http://kaidomain.com/p/S026300.Nichia-219C-Neutral-White-4000K-CRI92-LED-Emitter-with-KDLIGHT-3535-16-16mm-x-1_5mm-DTP-Copper-MCPCB
Since I have these LEDs as a triple in my S2+ and I am loving it, I hoipe to get a very nice High-CRI trower (i.e. more throw than that triple S2+ ;)) with this combination.
Sorry to hear that,hope you will end up with best solution. I have xpl-hi on the way, hopefully next week I will have a chance to test out that driver since Sofirn claims 4.5Amp and 1300+ lumens.
I will do a short review also
I am on the same boat, NikolaS. I am waiting for a C8T on its way in the slow boat.
Cheers :-)
Good thing it was free or I would be really mad :slight_smile:
Vf of LEDs in parallel doesn’t alter.
They don’t “avalanche”.
But if badly mis-matched, the lowest Vf one will take the majority current.
Or badly flowed onto a poor MCPCB, the one with the weakest thermal path will overheat soonest.
If one turns blue, it is getting far far too hot, and will never be quite the same again. DTP copper MCPCB is essential at these current levels, standard aluminium one hopeless, we learned this here years ago. It seems Sofirn have some catching up to do.
Yes I know the Vf of any given led doesn't changes because of parallel arrangement, Tom Tom. Leds in parallel will, however, share the load current, each one its own piece of the cake and thus their Vf only raises up to the corresponding shared current value (just ⅓ in this case for well matched emitters), which of course is going to be a lower value than that of most more poweful single emitters at the full current.
Cheers
PCB have big mass 30mmx1,5 and most obviously haven’t been heated properly resulting bad joints. At 6 Amp each led is taking 2 Amp which is not too much trouble for XP-G3 but results are more than bad…
If I get my version, I will make some makro-shots from the side of the LEDs (If I don’t forget that…) to see if they are sitting properly on the board.
2 Amps per LED really shouldn’t be a problem for the XP-G3 even on aluminium.
This C8 Host gives you many possibilities for 5 or 7 LEDs with TIR Lenses. Would love one of those.
I am right now a bit disappointed with my ThorFire TA13 (aka Sofirn SF30), the zoom mechanism isn't working smoothly and even gets stuck, it may have to do with me having to submerge the head a couple fingers in white spirit to unscrew the bezel for modding, though heck, that was weeks ago. Small rubber bits are coming out of the head, these for sure should be the inner o-rings getting @#$%. Grrr, is this OEM doing their research right?
Related: http://www.taschenlampen-forum.de/threads/sofirn-sf30a-modding-review-zoomtaschenlampe.57181/
Cheers
Please don’t keep on mentioning Thorfire. These are Sofirn. And it seems not great. They have gone their own way, seemingly without understanding first principles.
Whereas Thorfire are (IME) absolutely solid. Every one. Unless you know differently ? PS: dipping the head in white spirit is hardly a fair test, not at all surprised that you damaged some things trying that.
That’s all.
I'll soon be testing the C8T, Tom Tom, and I'm more or less sure it'll work right. The issues with the C8F are a combination of different emitters (XP-G3 vs XP-G2) plus an inadequate MCPCB, this latter latter being the most hurtful.
With regards to my TA13, for some reason at least one of the inner o-rings is becoming damaged and I don't know why yet. We'll see.
Cheers ^:)
Okay, I just got mine with the XP-G2s (or -G3s, whatever). Hmm, looks like the whole square is phosphor-coated, so -G3.
Anyway, wow! Nothing wrong with mine. So, nope, I ain’t gonna be taking it apart. :smiley:
Seriously, youse can dissect yours to your hearts’ content, but unless there’s some pressing reason to do so, and risk shearing off any LEDs, I ain’t a-doing it.
Gotta admit, this is my first triple, and I was expecting 3 separate but overlapping beams, loads of artifacts, but this is nice. Looks like one tight beam for what’d be 3 grouped 20mm reflectors.
Okay, due to the G3, I got the expected color-shift in the beam. Neutral hotspot, cool spill, strong yellow corona. Would G2s be a better choice?
Nicely lubed tailcap threads, buttery smooth, not scratchy at all. Nice firm click of the switch. Guessing it’s easily over 1000lm with a 30Q, via ceiling-bounce tests.
On high, it gets very warm, very fast, so it feels like there’s a good thermal path in there. Anyone check for thermal goop? I forgot to look at earlier posts before writing this…
Anyway, I’m suitably impressed. I was expecting a not-as-tight beam as a regular big-reflector C8, but this is… nice! It’s kinda like a domed XM-L/-L2 in a C8. Quite a bigger hotspot than my XP-E2 C8, of course, but it’s still very usable. For more throw, I’d stick with an XP-L HI (or extremely high-strung XP-Gwhatever), but as-is, this trip XP-G3 is quite good.
Best of all, the UI doesn’t piss me off. I almost cringed flipping it back to low, almost expecting the blink-on-low to switch 3/5 modegroups, but… nothing! Low, medium, high, yeah, doubleclick for strobe, but usable modes!
Damn, I can’t find a single thing wrong with it. :smiley:
(Well, okay, aside from the misbehaving G3s as far as color-shifts.)
If you don’t have a Nichia 219C flashlight yet - get them.
4000K or 5000K doesn’t matter, these LEDs produce such a nice light.
Just read through the MF-01 Group-Buy thread - all of the 219C owners are blown away from that beautiful light.
I will make this and put a BG FET+1 driver in it to power it
L4M4, the onboard driver in this torch is quite good, I'd just swap the emitters and be done with it.
Cheers :-)
Just got my C8T and it’s a beautiful machined without flaws, beam is also great even better than Convoy XP-L Hi. But the best is how powerful it is !
4.2Amp on HI with LG HG2 and 3,89A after 30 seconds
Quick lumen reading shows
Moonlight 1,5 lumen
Low 67 lumen
Medium 430 lumen
Hi 1320 lumen !!! X
At 5 metters I got 71,5 kcd for 534 meters of throw.
I don’t have any plans for modifying this one but maybe AR lens ,and stainless bezel :+1:
Haven’t you used the light before disassembling? Did it work then?
You took the light apart and reassembled it with a bezel from a different light and manufacturer. I won’t be surprised if this bezel - due to different construction - is not able to press the MCPCB against the shell. You mentioned you couldn’t screw down the bezel completely because of a thick o-ring. But this might also be caused by different or too short threads.
XPG3 loves heat i have XPG3 doing almost 9amps and they get really toasty. This would be why they un-soldered them selves the stock board can not handle the current. The stock board may not be making proper contact with the light its self if its not fully flat on the bottom.
Just to inform XP-L hi version or C8T have DTP copper PCB 16mm with nicely spread silver thermal grease underneath,and two screws for fixing in place. Tint is also amazing around 5700K maybe V3 2B I would say, much better than U6 3A .
Even if the board isn’t perfectly flat - we are just talking about 2Amps per LED and evenly spreadheat transfer paste - that shouldn’t be a problem
