Mine came in today and looks good. The inside of the barrel for the batteries had a few spots I smoothed down and the threads are a touch gritty, but that’s easily fixable. Not dark yet, but still fun to play with. I like the ramping UI more than I thought I would as I’m used to being conservative with battery life (backpacking), but I realized I really don’t care about efficiency for this light and the ramping is just so much fun. Double-click from off is fun too
For the config UI, I’m not a fan of it advancing automatically through the options as a new user. With the blinks being the only feedback you get and not knowing what you’re looking for, I’d far prefer that it just blinked the number of the current setting (or maybe even the value of the current setting?) every 3.5 seconds rather than advancing. I’m sure I’ll get used to it and I probably won’t spend much time in config. Not being able to see the current value of a setting (if there is a way, I haven’t found it yet) makes it tougher to know if you have the config set the way you want. This is just some feedback and in no way diminishes the function or value of the light. Heck, might even get me into the firmware side of things
I wanted to check out that bike mode strobe and after awhile, I finally got myself into Strobe 1, but from there, a click just turned off the light and a click/hold caused it to ramp. I tried explicitly setting the strobe mode to 3 in case it was just set for 1 strobe rather than all and I think I did it right, but not sure. It was probably set that way by default, but again, can’t tell. I’m sure I’m doing something silly and I’ll get it figured out eventually. I don’t think I’ll ever mount this light to my bike, but a preview for the FW3A will be cool!
LEDs are centered, switch LEDs look great, screws I can see are panhead and look fine (didn’t take head apart), and children are terrified. All in all, I’m happy
Thanks all for the hard work that went into this!!!
My only previous application of D-C-Fix was on the inside of the lens (on a P60 drop in I wanted to make floodier). Light loss is minimal (<5%). I’m assuming the bezel unscrews but my feeble attempts have so far been unsuccessful.
Have you seen my videos? This one https://youtu.be/rdwah7HJAJA shows me going into the blinkies. It’s dbl click, short pause, dbl click, then single clicks to go up through the 5 different ones. Your timing might just be a bit off. Once in blinkies you have to advance through them before 1.2 seconds each click. If you stay on a blinky mode longer than 1.2 seconds it locks in.
I also have a video showing the config menu. Once you get the hang of it, it’s easy. The cheat sheet shows the default settings, so just try changing one thing at a time and verifying it worked.
A while back, I took some beamshots of an EagleEye X6 and a Convoy S2+ triple comparing d-c-fix and a holographic diffusion film from Luminit.
In that same thread, ‘saabluster’ mentioned the layers of diffusion material used inside newer TVs. I haven’t tried any on a flashlight but I’ve had several TVs apart for repair and the material looks promising. It’s also cheap if you keep an eye out for TVs on trash day.
I think what I had in my head was a very light blending of the beam. The 40° diffusion film probably cuts your beam distance to less than half. That’s not what I was wanting. The 10° looks promising.
Is the DC FIX stuff available in different amounts of diffusion? That looks closer to what I wanted.
Beam shots before/after DC-Fix? I have some for the BLF-A6… not the greatest shots, but it might at least give some idea what to expect.
It’s worth noting that it does not change the tint. It just blends the various parts of the beam together for a more consistent tint. Usually the hotspot is one color and the spill is another color, but a diffuser reduces that by blending them. In case anyone was wondering why the light on the right looks warmer… it’s not; it’s just more consistent.
Another trick, go backwards in strope:
Strobe Modes:
The normal way (RAMPING: 2x, 2x, Y clicks [Y= 1…4] ) is time sensitive because of the lock in modes. And I got PMs people are not quick enough for the Y clicks, because the Y have to be done right after the second double click.
If navigation is hard, try:
RAMPING from off/on: Double click, double click, 4 clicks in a row. Now you are in the 5th strobe = 10 sec beacon.
MODES from off/on: Longhold (over 1,2sec), 4 clicks in a row. Now you are in the 5th strobe
Now you can go back via click&hold. You can go back 4 times, then comes OFF.
If you go backwards you have time to do this.
Here are a few detailed pics of my near perfect Q8. I've found nothing to complain about with the workmanship or performance. Comparing this by eye to the performance of a few other lights with similar specs, my sample somewhat exceeds the factory specs given, without any modifications. I'm using Sony VTC6. I plan to bypass the springs.
I disabled the strobe and all functions of the indicator light. I do miss the double-click from turbo to get back to the previous setting, like the D4.
Thanks again to Miller and the team for the best bang for the buck I'll ever get in a flashlight!
MAD777, that first pic makes me hungry! It’s early here, finishing up a cup of joe, and that looks like 4 over easy eggs…. my Q8 is hung up in Houston so I can’t even make toast!
Nice shots, looking forward to seeing this light…
Number 1 is hung up in Houston, still, number 3 is now in ElPaso, TX and number two is still sitting in LA. I recently ordered a couple of things from Banggood that have caught up to number 3 light, in ElPaso, even though the shipping seemed much different. I guess they’re playing with my number 2 in LA… hope they leave the cells in it when they’re done.
