Lux meter on the Google Play Store worked well for me. It saves the maximum figure recorded so you can go back and look at it. I don’t know how accurate it is as it will depend on the hardware calibration of the light sensor on your phone, but it is great for comparison.
If those just came in, can you take pics of the chargers.
The first of several of my friends that ordered should get his very soon also. He is wondering if the charger issue has been corrected.
He already has a 19v laptop charger ready to go if needed
After nearly 3 mths of waiting with a pre order with gearbest then swapped to banggood, my DX80 finally arrived!
It is bright all right and so far that is just inside during the day.
I charged it up using the Imalant charger and although it did get warm it made it through the cycle.
We are on 240v here in Australia, so maybe it is the 110v power that is causing failures.
This is what 1 person said on the site about that app,-
Google Play - Lux Meter
Has very limited range I have a very bright flashlight that I was hoping to test, but in anything brighter than a 100w lamp it reads 6000lx and will not go higher. On footcandles it stops at 558ftc. If you want to read relatively low light levels, then this would be a great app.
There must be a way I can test my flashlights at home ,
