I tried it but still failed. Here’s what have I done:
1. Soldered 3 SMD LEDs to channel 1.
2. Tested the LEDs, all three can shine together if I direct drive any one of them.
3. Soldered the B pin to bypass because I use no pots.
Now I have difficulties connecting the washer PCB to my switch board (Manker E14), tried several ways but still failed.
Here’s my connection scheme, I hope somebody could help me understand this wiring thing.
It’s been a little while, but I cooked up another one over the weekend. A Convoy M1 with an XP-L V6 5000K and a nanjg105c driver with Babka firmware. Used a 750 ohm bleeder on the driver. For the tailcap, I used 6 green LEDs on a Rev5.3 board, bridged to a single channel using a 20K ohm resistor. It’s bright. I haven’t measured amp draw, but with a 20K ohm I doubt it’d be much.
Nice work there. I see some blue. Before reading your post, I thought you had a green switch cover with some blue emitters underneath.
Is that OSH board the board that normally has the switch installed on it? I have never looked at those. If it is, you seem to be connecting one switch board to another switch board. Maybe the pic just doesn't show the hole in the center for the switch's button.
I think Wieselflinkpro was saying that you can hook your switch (with it's own PCB as you have pictured) directly to the board that has the emitters and resistors. He called your washer pcb because it looks a little like a washer with a hole in the center.
Please excuse me if I'm totally missing something. I didn't try to dig back into posts to get the back story.
According to the image, I think you have the polarity reversed. With the “HGJ-16” up top, I think the right leg is negative. I always double check myself with a DMM each time just to make sure.
A 1K ohm resistor is probably going to be too little resistance depending on your LEDs and desired brightness. For 6 blue LEDs, I usually use 10K ohm. 20K ohm for 6 green LEDs. Around 6.2K ohm for 6 red. For only 3 LEDs, I’d double the resistance (ie, 20K ohm for 3 blue LEDs).
IRL, it’s pretty green. I don’t notice any blue, but I’m colorblind. Guessing it’s just the color balance of the image. Here’s a pic of a few sitting on my desk. I know these colors are off. From left to right: green+blue, white, blue+white, blue, green. I’m not too good with photo editing to properly adjust the colors.
0.56 mA was too much for me. Sure it looked cool during the day, but it was excessively bright at night. So I tried a 4.64K ohm resistor and measured 0.30 mA. That still was too bright in the middle of the night. I like that the tailcap shines nice and bright since it’s a neat feature, but it also needs to be reasonable. Then I tried a 6.74K ohm resistor and measured 0.20 mA and that seemed about right. Here it is next to the Meteor M43 (on the right) turned on, which was my target brightness.
One thing I find a little odd, you have to switch between the 2 potentiometers
Wouldn’t it be better to use those 2 potentiometers to control both LEDs brightness to be able to change the effective light color
and the switch to turn it off and on
for example from Green to yellow-green-yellow-amber-orange red-red
I saw later the 18mm top board but that does not fit a 16mm host, the potentiometers seem to be further out than on the 16mm bottom board
A quick look at a Convoy switch shows me definately polarity reversed
If you got only one sort of LEDs there is no need for a balancing resistor, but thinking of it some balance resistors would be useful to even out small differences of the LEDs like in the first batch of Q8s with uneven LEDs
I liked having a low and high “setting” I could easily toggle by flipping a switch. Being able to vary different colors with the pots sounds cool too. Feel free to continue development in my absence. I make no claims on the designs.
You would have to experiment with bleeder values and tail resistor values to find a set that works for the biscotti driver without messing with the UI timings too much. I have not tried that for biscotti, I just know that the BLF-A6 driver works with all kinds of values and that the BLF X5/X6 driver is very choosy.
When doing mine, I’ve always just added the bleeder. I’ve never even tried without. Figured it would just take less time to add it rather than to monkey around and try without.
