Now what if we take the 18350/21700 zoomie above, apply this idea, but shake it up slightly….
The central LED would be the Blackie. Around it 8*Nichia E21 CRI 9080. We’ve got an 18350 pencil-beamer which outthrows TN42. Theoretically TN42vn too. And we’ve got a reasonably efficient hi-cri flooder in the same package.
Problems:
more complicated driver
yet another cost hike
strong output discontinuity on the switch between E21 and Blackie
I think this thread is best used for generic discussions about future projects. It will be a whole lot easier to keep track of your new design if you create a dedicated thread for it. That way, none of your early design notes will get lost in this thread.
My only real desire for a future BLF-light is too underwhelming to gain enough traction, I mentioned it once, and here again, one can hope :innocent: :
a 3 xNiMhAA-in-series light (batteries side-by-side) with common lineair driver like the BLF-A6 FET+1 driver or a Narsil driver. Short, tube-style with a quad (to keep the length as short as possible) low voltage led (Luxeon V is the current lowest voltage led that fits a Carclo quad, that should be a great choice) . The dimensions should be as low as L=80mm, D=34mm, which is very significantly lower than any 4xAA lights out there. The output will be very efficient and over 1500 lumen for most of the runtime. At around 4A current draw the light does not need a stepdown to prevent self-destruction, it can be handy though to keep the temperature low enough to hold.
So extremely safe, high efficient output, great small size, and it takes the most common alkaline battery in the world as backup,
I personally think this is an excellent idea. :sunglasses: I was pleasantly surprised to see in HKJ’s review that you can actually shove 10A through an Eneloop. A compact light that pushes the capabilities of NiMH is certainly interesting in my opinion.
Still some interest in a 3xAA light. It is also interesting because the overhead voltage between a modern low voltage led and 3xNiMh-in-series is close to ideal again for lineair drivers (7135 based) or even FET-drivers: good efficiency and still good runtime in regulation.
I did a test holding a 3xAA carrier with switch (phosfor-bronze springs) against the head of my LuxeonV-modded D4. The Eneloops were not quite full but it gave me a steady 1250 lumen for the 10 seconds that I managed to keep the parts in place in the entrance hole of the sphere.
I want the long version of that very light, with the three AAs placed nose-to-tail. I know it would be about 200mm / 8 inches long, but I like long lights
Of course the various 4xAA lights out there fill that niche as well (D40A, EA41), the merit of this one is that it is exceptionally thin and short.
@Phlogiston: 3xAA in a tube would work just as well (even a bit better because the resistance in between the batteries is virtually zero), that is of course a matter of preference, I like stubby lights, you like long and thin.
You can do this by combining tubes from a SK68 clone and a “3W Police” flashlight (see the lego thread)
I’ve still got a Brinkmann 3AA tube light in the “do something with this someday” bin.
Google finds a lot of other 3AA flashlights (limiting search with /Tools/verbatim, and then choosing /Images)
I’d like to see a djozz-inspired 3AA BLF light myself.
(I’m waiting for the flashlight design where you click the button and the light head extends little propellers and flies over to hover and illuminate your target, while you control it from the battery tube)
