WaylonJennings, I to like the idea of a single 26650 light! Thanks for the suggestion…… :+1:
Since the Miller has apparently ‘left the building’, with no real explanation to anyone as far as I have read; has anyone taken the helm of this thread of neat ideas & donations???
Just curious… Because if there is no leadership, how will anything happen as far as a ‘new project’??
At that diameter, I think an optic makes more sense for a triple or quad. It gives you an easy way to change the beam shape, to some extent. I think there’s room for a 26650 light which could also take 21700 with a centering sleeve (ie. good springs on both ends).
But to be honest, I think a single emitter with boost driver and somewhat lower power would also be useful. It’s not like a light that size can dissipate a lot of heat anyway. It would be a nice change to have a light designed for maximum sustained output instead of burn-your-fingers-in-30-seconds turbo mode. Turbo is fun but we already have it in many forms.
Some post’s on Facebook makes it seem that he is OK, but it does seem odd that he dropped of the BLF world completely. AT first it made sense that he just needed to step back for a few days, but it is very surprising to me that he would not have just taken a quick peak at the GT thread and see the concern by so many and just make a post or two. I am sure he will be back when he is ready.
Someone might need to take the lead on the new projects thread just to move things forward. It will have to be someone who who knows the technical side to get a good start and then the process side to get it manufactured. I am sure that others familiar with past projects will do a great job.
Excellent question cabfrank…… it appears no one knows.
The last known Miller sighting I am aware of was back on 5 December…. discussed HERE in the GT Thread. It appears he was alive & well then.
It does seem very uncharacteristic of the Miller, who was so involved; to just vanish without a word. Oh well…. stuff happens I guess.
It made things a bit difficult for TA & others at a critical time in the GT Group Buy…… But they overcame & things went very smoothly. They all did a stellar job!!!
As WaylonJennings mentioned…… someone with the familarity with projects & knowhow will probably step in and things will just move right on along.
Those already exist. I’ve got a DQG Tiny 7x xpg2. It does 2500 lumen and is pretty awesome, but I don’t like tir lenses. I’ve retired mine as it’s not very good for walking around at night.
Yes, these small diameter multiemmiter reflectors are only found on a few lights and I have no idea if they can be made to fit a different body. Obviously the emitter shelf would need to be raised if you put it in a body that used a single emitter. This means a custom machined spacer which I why I was hoping for a host that already came with a small multi emitter reflector.
I felt the U21 was a bit too big as far as head diameter. If that size is okay by you, then there are existing lights that can be used as hosts. Check out the Shadow SL-3.
I would be just fine with a smaller host as long as it could handle the heat of three emitters. The little DQG 26650 seems to heat up pretty quickly due to it’s small size. I like the small size of my SD26 and EC60, but I do not know how they would handle a triple emitter set up.
I am shocked to hear that the Aspire cells have been discontinued. They are so much better than the next best 18350 cell out there. I was hoping that they would start making a 16340.
Wow, that was 5 years ago. You can’t even buy it anymore, I assume. Flashlight technology moves fast. I think it’s time for another 26650 light.
We could take the A8 and install a TA driver running NarsilM, add a side switch and maybe make the head a little bigger to fit a triple reflector with xpl emitters. Like a 26650 version of the Sofirn C8F. IDK, but I like those kind of lights.
I can’t remember who asked… but the inquiry to Sofirn about a 26650 C8F has been submitted to Tracy.
I recently received a PM from Tracy on something, I will also present my interest bout this form to her.
More emitters makes the reflector smaller. Maybe 4 would work well? Sofirn already has a small triple reflector and Cutter carries a triple 5050 mcpcb that fits it. Triple 3535 mcpcb should also already exist. I don’t think I’ve seen a quad reflector light with a head under 44mm *which is C8 size).
