Looked up my orders, yeah, VTC6.
I figure I’m not going to be vaping or DDing a quad or anything, so I went for capacity. 3AH sounded good.
But yeah, lotsa people like the 5 and 5A, so am still wondering why.
That was the gist of what I was getting earlier, albeit in a roundabout way, but this about sums it up nicely.
I modded another nitefighter C8 style light today and decided to see what the SST-40 would do if I put it on the aluminum mcpcb that comes with them. I did put down good thermal grease to give it it’s best chance of surviving the low resistance FET driver, heavier wires and spring mod. Surprisingly it did not kill the emitter even with a LGDBHE4 which is a pretty good high amp battery.
I did this because I was curious how many amps they can handle without being put on direct copper mcpcbs. Ton’s of lights like the SRK’s and other multi-emitters are a lot easier and cheaper to mod if you re-flow onto the original mcpcbs. From this I would say that there is little to worry about even when using high amp batteries.
Does anyone know how many amps these SST-40’s can handle without putting them on copper mcpcbs? I wouldn’t think they could handle this much and now I’m curious what the max is.
^ DTP boards perform pretty close to each other (a few years ago relic38 and I tested a number of types that all came pretty close to each other), but I have the impression that in non-DTP boards there is a huge variation in performance. The best I have seen is a cheap (copper core) 20mm XM-L board that easily allowed to run an XM-L2 led at 5A while performing only 5% less than a Sinkpad. But on the safe side I think 4A is no problem for almost any ledboard, also with a SST-40.
Thanks for the info.
Heres djozz’s test on the SST-40.
Today I modded a LuckySun D80 with a BLF-A6 driver and a Black Flat on led4power’s new, promising, Oslon board.
Unfortunately the modding attempt took all day and turned into an investigation of this new type of board, and this is what I found:
In all steps above I made sure that the led was perfectly centered and in focus, they were finished mods.
Conclusion: I can still think of other explanations, but for me the most plausible one at this moment is that this new type of board (at least the one that I did the test on), when heat-shedding really counts with a severely overdriven led that has the small Oslon footprint, performs not as good as a DTP board. I hope that I will be proven wrong by others as I really want that easy to use well-performing Black Flat board.
Black flats also do not come in flux bins they put them randomly in the tapes
likely this ones were on the low end of efficiency
Yeah, but reflowing another LED yielded the same result while switching MCPCBs brought an improvement. This is a strong indication that MCPCB was the reason for low performance.
That’s indeed a disheartening result.
Yeah you definitely want DTP if you want to get the most out of this LED.
Thermal paste is a must.
If you want to do 5-6A then you need a proper heatsink, not a flashlight host, to dissipate the heat.
Thanks Steve.
I suspect heat spreading on oslon black flat is pretty bad, bottom pads are very small so power density (W/mm2) is very high at board-pad junction, over 15Watts per 1mm2 of LED die.
This board was designed for IR oslons (black flat was still not very known at the time of design) , and it should perform much better than existing insulated boards like non-dtp copper pcb for XP, and Bergquist 804087 .
I will have two oslons flat for testing soon,after test I’ll do “autopsy”, I’m very interested in how cross section of oslon flat looks inside (thermal path specifically). Plastic case of oslons always was downside for me, I assume there is no ceramic like alumina inside, just copper pad, the question is how thick.
I did some calculation, mosx have thermal resistance equivalent to <250um of solder layer, and if I remember correctly someone did the test noctigon vs. sinkpad 2 (gap on top) ,and there were no visible difference in performance for xm-l2 and similar leds, but they have ceramic substrate and pads have decent size.
that was me, and the led was a XM-L2, so a way bigger thermal pad (13.3 mm2 vs 2.7 mm2 for the Black Flat, 5 times bigger)
It was actually this test/thread:
but I see there is identical picture in your thread also. Somehow either I missed your thread or forgot about it. Subscribed
Yes, the observation is the same: with the XM-L footprint, the thickness of a solder layer under the led is not critical as long as you get rid of the thick dielectric layer. But apparently at the same powerlevel but a 5 times smaller footprint, the details of what happens under the led are more critical, makes sense
I ordered some MosX oslon boards for testing too , and i already have some Oslon black flat leds (LUW HWQP) here …
Right now i tested one at a Thorfire C8S on a DTP board (without a driver) , with AR glass and i get otf 720 lumens & (only) 170kcd @ 5 amps , using sony VTC5 .
720 lumen (@30seconds?) sounds really consistent with my Supwildfire driver-less thrower (350kcd ) which is 700 lumen but does not have and AR lens.
Yes , about 25 seconds after turn on .
Focus seems good , now i use a 0.3-0.5mm centering ring , i don’t think i can get a better focus for better results …
Stuck one of the Luminus SST-40 emitters on a 20mm SinkPAD and put it in a baked Eagle Eye X6 with a Bistro driver. On a 38A 2100mAh Efest it makes 2601 lumens out the front. I don’t really care for the blue tint side of things so I cut a piece of 223 Lee Filter and put it on top of the AR coated UCLp lens. Now I have a 5500K tint but with a 14% loss to around 2200 lumens. Looks good though, nice spot with an aura and then a useable spill.
Nice, they state these are 97% throughput but even after adding the lee filter it’s still at 86% so it’s worth it. You won’t get 2200 lumens out of a similar tint XM-L2.
