Help me choose a good 1xAA/14500 flashlight
Its a flood to throw light. I have several and none of them are very good at flood. Sounds interresting
that a 1.5 volt AA can provide higher lumens than a 3.7 volt 14500. Could you please inform us with
your measurements(!) of the C78 on 1.5v and the AA S1 on 14500, as the C78 is not found in Don´s
splendid dokument.
In terms of hotspot/throw with AA's, the c78 is about same as the skyray s5, about 1300 arbilux, this compared to 450 for the J4, 300 for the C3 SS, and 100 for the AA-S1.
For flood, measuring at half the radius from center, the c78 is about 40, the s1 about 15, the J4 15, and the C3 SS is 10.
I admit, I dont know what arbilux stand for. But if its the same lux as Dons there is a big difference
between your figures and Dons
The J4 is 1460, the C3 SS is 1391 and the S1 is 1255 Lux. Not a big difference. In lumens they are 262, 250 and 225.
With AA batteries the figures for all these lights are lower. But according to your figures the C78 on 1AA are much
brighter than these on 14500. For me there is something that does not add up. Do you use the same metode as Don
when you measure. Are the figures you gave measured and how?
Hello everybody
speaking over flood to throw .What about the good old Romisen Rc 29 It has Q5 emitter single mode bigger flood than c78 and workmanship is better.
Cons : sharp switch ( can destroy your pocket) but perfect tailstand, a bit bulky, only up to 1,5 v .
All my non flashaholic friends love it.
By the way Thanks for the warm welcome
It is true, build quality of the KD Romisen RC-29 Q5 is much higher (switch+threads) and it is brighter than my 2 C78s. But it is very bulky and needs 3 full turns of twisting, resulting in 5-6 actions to go from flood to throw. If it was push-pull and had the switch of the C6/C8 ... it would be the perfect flood-to-thow light on 1xAA.
I agree. The RC29 is a very good light. The C6 is better, but its a RCR123 light. I still vouch for
the AA S1 as an AA (14500) light and until proven by measurement, I dont believe that an AA 1.5v
light has more lumen then it. Look at Don´s spreadsheet and be convinced what lights provide
the biggest output on a given battery. Links at all Don´s posts.
Arbi-lux (arbitrary-lux) just refers to the fact it's lux not referenced to distance (as lux itself isn't) because I didn't bother to bust out the meterstick. However it's self-consistent and thus can be compared among themselves. What are Don's numbers measured at?
The c78 as I've mention in other threads has better optics than the c29 (and thus likely similar romisens), and pretty decent quality if you get the LT version. The only place the romisen is better is at the widest flood when it finally smoothes out.
Thanks for info. Maybe Don can answer your question of metode? I think that numbers aside, you get a better
impression of different lights when they are all measured with the same equipment and in the same way.
I like the optics of the the RC-29 better , because it has a larger flood angle and beam has less artefacts on flood. So it is better if you want to use it as a pseudo Zebralight.
Hey, thanks for the replys Laughing For 1xAA light 1 mode should be enough, but for 2xAA or 1x14500... I think multimode is a must.
Ok, on the one hand, we have an AA-S1 with good spill and on the other hand we have a zoom-to-throw lights. So... is there any beam shots comparisons? I mean, "normal" lights like AA-S1 and one zoom-to-throw light.
Maybe this can help you!
Video comparison of AA-S1 VS a flood to throw (both with NiMh). Both as OSRAM golden dragon LED
Dont forget that digital cameras autoadjust brightness
Nice find, fran, tranks. Good video but bad quality Frown
Which c78 are you comparing it to? The one I have has no unevenness in the whole zoom range, whereas the rc29 has squarish (cree) artifacts until all the way in flood.
agenthex: I was talking about full flood , which is my most used mode on flood-to-throw lights. I don't have any real usage for the throw or half-flood. The RC-29 are from KD and the C78 from DX. Maybe we have different models of those lights. I am thinking about buying those pseudo Zebralights from Ultrafire.
The part I was wondering about was this:
I don't see any artifacts on flood other than the typical "ring" around the edge of the flood that all these light have, and different c78 "batches" are known to be completely different.
And I wondered about your complaints about the optics of the RC-29. I should have said: The RC-29 has an even smoother beam than the C78 on full flood and the brightness is more evenly distributed from centre to the edge on the RC-29 (on full flood).
On the other hand I have given away all my RC-29 (had 3-4) and kept the C78 .... go figure. I like the C78 overall design better (blantant copy of the led lenser P5), but the RC-29 is the better light in my opinion. But the twisting action + the already mentioned sharp (tactical ) switch ruins it for me a bit. I would buy a C78 for myself and RC-29 as a gift/present for others. I personally like the ability that the C78 fits perfectly in this headband and makes it into a cheap high power headlamp.
To clarify again, when you start with square image at full zoom on the rc-29and start twisting to flood, artifacts of the cree square remain in the beam until you get to almost full flood. Now, it's probably not a big deal like cree reflector rings aren't a big deal in real world use, but it does indicate that the lens design is not as good. Still, I would agree the rc-29 is more versatile at full flood since it can illuminate over twice the area, it just takes a while to get there and sometimes you accidentally turn the light off. The slightly better build quality/polish also helps makes it a better gift.
Also, for my specific samples, the rc29 at 2.5A draw is same brightness as c78 at 2.0A, and a bit blue.
Sashix, if you read forolinternas you will see that the sipik http://www.dealextreme.com/details.dx/sku.39585~r.43033281 has a better construction, quality and same power as all C78´s. Also capable of both AA and 14500. Pity only 1 mode. I have ordered 1, still not arrived
Also in gray http://www.dealextreme.com/details.dx/sku.39584~r.43033281 but a little more expensive
Lets see .... Shekor charger has changed , for the worse apparently .. SO at this time I would say Xtar - 2 bay charger ...
If I know who made the Shekor charger I would contact them about stuffing up what was a good charger .
What do you mean? New versions have gotten worse or something happens to yours? And as far I remember, Xtar charges batts a bit higher than Shekor. I found Shekor @ KD for $10,28. But where I can buy Xtar? Only found it @ ebay for about $15. Is it a good price? Thanks, Matt ;)
PS: thx for the info, Fran ;)
