Thanks for your replies guys.
I have included all of your requests in my list. If I don't manage to get a code for everything you want, I will re-request it again in Monday!
Sorry bilakos I mean this code please:
https://m.gearbest.com/led-flashlights/pp_236486.html?lkid=12659435
Thanks.
^ I hope that is bilakos aff link you have included in that request and you aren’t trying to make money off his thread.
Hi, I didn’t know we can make the money from the thread? I just copied the link from his expires deal. What’s wrong with it?
No worries mate.
Mapache thought that you might were using your own affiliate links but I just checked and the link you provided is indeed copied from my thread
There is nothing to worry about.
P.S Mapache thanks for your interest!
Active codes
3/2/2018
Available for these countries:
HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,PH,GR,NL,HU,SK,CZ,HR,BG,SI,RS,TH
I haven’t seen FR in your country list for quite some time…
Here's another set of deals guys!
Everything is available in the OP as well.
Active codes
3/2/2018
The Boruit RJ - 02 R5 300LM IR Sensing LED Headlamp comes up as $6.99 for me?
For me too.
I am sorry guys
The correct price is $6.99
Working from my mobile phone is quite difficult!
https://www.gearbest.com/chargers/pp_226450.html
Code for this charger possible?
Edit: I see UK plug is selected when I go to the link, I need US plug
Convoy S2+ CREE XPL HI code is expried, I wil try tommorow again.
I believe that I will be having a code for this charger by tomorrow.
The code seems to be working fine for the V2 1A tint.
Have you used a similar code in the past?
Yes I did buy 3 of these with your codes in the past :cry:
Convoy S2+ 365nm Nichia UV Waterproof LED Flashlight - bilakosJ199 code has expired.
Could you please renew the code for this?
Thank you
Would the Boruit RJ-02 be good for general work such as working on cars and getting up in the attic? I’ve got a Black Diamond headlamp but it’s only 200 lumens and the batteries do not last very long since it only use 3 AAA’s.
Wellp, it’s only about 300 lemons, so won’t appear that much brighter, but the 18650 will last forever by comparison, and will have essentially constant output ’til it runs down, vs 3×AAA which is a constant steady decline in brightness from the first second you turn it on.
But it’ll take any 20mm TIR lens, so you can swap in a wider-angle lens (eg, 60° or wider) if the come-with one is a little too throwy, or swap in a really narrow-angle one (eg, 5° or 8°) if you want more “reach”.
Most cases, I keep it as close to minimum as I can set it, and that’s usable light (for me). Only rarely do I need more than that, and you can get instant-maximum by going to wave on/off and turning it on.
Runtime is about 3hrs+ (about 1A in a 3400mAH cell would be 3.4hrs), and that’s at full-tilt. Anything less, and runtime will be way longer.
