LiitoKala Lii-S1, successor of the revered Lii-100
That combined with automatic stopping of charging would make sense, otherwiseā€¦
ā€¦yeah, and the power bank thing on Lii-100 tends to stop working in some circumstances anyway
Just sent the following email to these fellows:
We'll know soon.
Cheers ĢæĢæĢæĢæ ĢæĢæ ĢæĢæ Ģæ'Ģæ'\ĢµĶ‡ĢæĢæ\Š·= ( ā–€ ĶœĶžŹ–ā–€) =Īµ/ĢµĶ‡ĢæĢæ/ā€™Ģæā€™Ģæ Ģæ ĢæĢæ ĢæĢæ ĢæĢæ
Uhā€¦ ohā€¦ we need a coupon codeā€¦ a significant one at that. :slight_smile: I am not paying more than $2.99 for it.
I donā€™t see a NiMH display, but the description does mention NiMH support. Weird.
Soā€¦
Instead of fixing relatively high 100mAh for NiMH they remove support altogether?
Instead of fixing power bank function they remove it?
Instead of that we get (useless?) display
Wow
Hope above proves wrong though :slight_smile:
But if it is not, then this is not Lii-100 relacement :slight_smile:
I misread. Description does mention NiMH support, but there appears to be no NiMH indicator light on the display.
My 100B (the one without power bank function) actually does not overcharge cells like the 100 does. I wonder if itā€™s the power bank circuitry thatā€™s to blame somehow. Maybe this S1 will not overcharge because it has no power bank function?
The display features indicators for lithium chemistries: this is termination voltage adjustment. There's no charging parameter or algorithm ambiguity for Ni-MH thence no need for an indicator.
The powerbank function may be a bit tricky with the rail and contact resistances getting in the way.
Cheers
Sure it looks nice, but whatā€™s the use of it?
I just put my cells in a charger and thatā€™s it. Iā€™m not going to watch the numbers on the charger for several hours.
What I would like is time remaining until 100%
No Ni-mh charging?
Yes there is.
I think they fixed the over charging of the 100. I canā€™t remember if Iā€™ve tested all three, but at least the one I tested terminates at 4.18V.
The one I received last month overcharges.
ā€¦ Then itā€™s a cheap charger? If there is variance resulting in some samples over chargingā€¦ I think Iā€™ll re-test all three of mine soon.
My home Lii units pump up to these voltages when set to 4.2V li-ion:
  • Lii-100 Mk1: 4.22V.
  • Lii-202: 4.14 and 4.16V.
Furthermore, my Lii-202 fills up Ni-MH cells significantly more than the old Lii-100 Mk1.
Cheers :-)
^ Do you think final voltage is also dependent on type of cell and internal resistance?
The maximum cut-off voltage of each charging rail can be directly read over it when the charger is in CV mode, which is easily caused on purpose by attaching some high resistance in series with a cell like alligator clamps with magnets. Actual maximum resting voltage will be somewhat below this value depending on termination current and rail to cell total resistance.
Cheers :-)
How do you tell if you have an Mk1 or some other version?
Also, is 4.22V cellā€™s resting voltage right after youā€™ve removed it from the charger? Or voltage while still charging?
Looks like this one and was bought on April 1st 2016, Pete7874. It's :-D vintage!
After removal from the rail plus a tiny bit of resting. Some would say it technically overcharges.
Cheers :-)
Nice find Barkutiā€¦.
Wondering myself how this one goes about itā€™s business, would like some quality chargers for those occasions I give away a light. :slight_smile:
My MAHA dedicated NiMH chargers have two charging rates for NiMH cells, standard and soft charge. Standard charge rate is 2000mA, one has 100mA soft charge while the other is 300mA, both are 8 bay chargers. The other day I was getting ready for a wedding, charging cells for my flash unitsā€¦ I had 5 of the 8 bay chargers going full out. These 2 MAHAā€™s and 2 Enova Li-Ion/NiMH with another Gyrfalcon also loaded. After the cells were done, I took my 2 sets of premium cells for two flash units and conditioned them in the MAHA chargers.
So my primary cells were charged, charged again, discharged, then charged again. I took 868 photoā€™s on my 1st set of 4 and my wife took 1025 photoā€™s also on her first set of 4ā€¦ neither of us got into the second set. Thatā€™s some serious work from the Pro level NiMH LSD cells! (FWIW, we didnā€™t change the camera battery either)
To have a small single bay charger that works well, easily used anywhereā€¦ from a battery bank or solar panel or the car or whateverā€¦ this could come in quite handy.
