First Post, choosing between a TR-J12 and FandyFire L1
Removing enough solder from the bottom of the contact disc to allow access to the driver is a good place to start.
I shall give that a go and report back :)
So I made some progress in that I realised there's actually another part of the head of the light which un-screws. Unscrewing this has given me access to the driver itself.
In doing that, the problem is obvious - the board has been broken when the head has been screwed back on, it looks like a pretty crappy design.
Here's the section with the driver, showing how it was as I opened it: http://t.co/NBa46cKY
And here's after de-soldering the remaining leg holding the two pieces of the driver together: http://t.co/pv6TIp6P
I don't see how I can fix this myself as it looks like the copper tracks on the board are now missing, hence re-soldering it would not work, am I right?
Ok, so I thought I'd start playing about and knocked up a join between the two sets of boards; http://t.co/J1TqnI2n
I get 12.38 volts at the red/orange wires which I believe I've soldered onto what's left of the pads.
However, I'm only seeing something like 0.38 volts at the black and white wires which should be leading to the LED's.
Maybe I've not got the wires on the right pads or maybe the driver is bust? Either way, it looks pretty b0rked to me :)
The good news is that Manafont has a replacement driver for ~$6
link for that please?
Probably quicker than waiting for DX :)
Link? or place I can read up more details?
Here's the link:
http://www.manafont.com/product_info.php/flashlight-component-triple-t6-cree-circuit-board-driver-p-7973
Certainly looks similar, though not quite the same.
It's an option I guess :)
Wait...isn't that a driver for triple XM-Ls?
Still don't know if it is parallel to the LEDs for 5x XM-L.
Since it's a B&B driver, it should work with 3 cells. I would estimate around 1,6A to each LED in that config.
That's the TR-3T6 driver, that would give you around 1 Amp per led
Hey, Which one is? The one that's pictured in my photos and hence comes with the torch, or the one from Manafont which has been posted?
This is the cool gadgets i owned.
It is a cheap chinese light.
For more information, see here. http://www.dealextreme.com/p/57096?r=88314923
..just me or the TR-J12 with LED's re-wired in series, equipped with either http://www.kaidomain.com/product/details.S020077 (cheap, but as it supports only 4 LEDs, center one would have to be disabled) or something like TaskLED Hyperboost (more expensive, but way more functional), and three A123 LiFePO4 26650's would be most lumens/$? :P
Surely it sounds just like a dream, but I'll try to implement that dream in reality as soon as I get it - it's marked as shipped for two weeks already, but China post has some weird randomness factor with delivery times - that KD driver (as well as six 26650's) arrived few days ago, while being ordered same day as flashlight.
TaskLED Hyperboost - what is that?
The manafont one
a LED driver - you can read more about it here: http://www.taskled.com/hboost.html
I'm currently doing battle with DealExtreme customer services, took them three days to respond to my initial query and their response was "check the forums for more information".
Not terribly useful, no amount of forum checking is going to solder the driver back together *sigh*
By the time I have a working flashlight there's going to be a new emitter out and this one will be a relic!
I've never been one for giving up easily, so I had a bit more of a play around with the soldering iron this morning and have fixed it :)
This thing is bright.
Going to re-assemble it now with the soldering done properly (ie: not using connecting wires to bodge it) and see how it goes - beam shots tonight perhaps...
