Youâre welcome buddy :+1:
Doesnât look like anything better than whatâs already out there.
Thereâs a new LiitoKala single slot universal charger, called the Lii-S1, which may be a successor to the great value Lii-100:
The thing that catches my eye about it is that it has an LED display for voltage & current, not an LCD one. I like that, because Iâm legally blind, and some LCDs have such low contrast or poor view angles that I find them almost impossible to read. I might order a couple after the Chinese New Year chaos is over
I have ordered it
Thank you :+1:
New concept: A mix between DC power supply and USB meter in the case of an powerbank, but without battery.
4 independent channels with 3A each, 2,5-12V. And WiFi control from an app.
https://www.kickstarter.com/projects/786154913/voltbot-visual-safe-charger-and-adapter?ref=recs&ref=discovery
Any chance we see a test of this âprofessionalâ charger?
https://m.banggood.com/Outdoor-20W-Multifunction-Portable-Manual-Crank-Generator-Emergency-Survival-Power-Supply-p-1225105.html
Probably not. After the one hour load test I would not be able to write anything for days
In reality I would have to do some setup with a speed controlled motor to test it and start plotting power vs RPM. It could be fun, but it would take a lot of time and I would have to manufacturer some of the test equipment first.
Hi HKJ, would you also consider tearing down and analyzing the black box ac-dc adapters that usually come with these sort of chargers?
Usually not, I only do a high voltage test from mains to low volt side. The inside is made about the same way as usb chargers.
Aliexpress have a big sale, that means it is the right time to post review ideas for discounted stuff from them.
IKEA STORHĂGEN
Battery charger with storage
When batteries are fully charged, this battery charger switches to stand-by charging so that you can store your batteries in the charger if not using immediately. When batteries are fully charged, this battery charger switches to stand-by charging so that you can store your batteries in the charger if not using immediately.
Keeppower L2 smart. I ordered it but not sure how good it is. https://www.gearbest.com/chargers/pp_286342.html
I checked that charger long time ago: Review of Charger Keeppower L2
Use this table to see what I have reviewed: Round cell charger index
Thank you HKJ
Thanks, iâd see why i didnât find the IKEA Storhögen - numbers are sorted as letters. So the 12 is between the 1 & two slot chargers.
Fixed.
