It is not available anywhere in China. I see that there are still some US shops which haven’t sold their stock, but shipping to Europe is prohibitively expensive.
I tried to buy them there before but there is a silly bug in their site: you have to select your country in a list and that list is incomplete, many countries are missing, also the Netherlands. And there’s no way around that so I can not order :confounded:
I just received an order from Liion recently and got the Aspire 1100mAh, but checking today it’s no longer available at Liion Wholesale or IMR Batteries. Wish i would have known I would have got more than 1 pcs. :rage:
I’m not too good at understanding the graphs (probably don’t have the patience to figure them out)
Can someone answer a few questions:
Are they are truly 1100mAh?
These are better (higher capacity, higher discharge) than the Efest 900mAh protected?
* In the review it shows the Ultrafire’s will deliver 7 to 10A, so the protection circuit on these have a higher “ceiling” than the Efest 900mAh protected?
(Efest’s show current being limited to 5A by the protection circuit):
It was my understanding that the Keeppower IMR 18350 1200 mAh battery from RTD Vapor was the same battery as the Aspire. I picked up a couple to have on hand when I finally decide on either a Astrolux S1 or a Convoy S2+, both with the shorty tube.
That’s the whole reason I purchased the Aspire 18350 cells. They work great but short run times compared to a 18650.
Thanks for the testing data HKJ. :+1:
These are nearly certainly exactly the same cells as:
Aspire 18350
Keeppower 18350 1200 mAh
However, I wouldn’t trust Ultrafire. They may change the cell they use under the wraps at any point.
Therefore I would prefer to buy Keeppowers unless:
UF was so much cheaper that I could justify the risk, or
I was capable of measuring the cell cell receive AND getting money back if it underperforms AND got it cheaper to justify the potential burden
This is weird, doing a search on that site there’s no Keeppower 1200 coming up…but if I do a google search they come up: https://www.rtdvapor.com/keeppower-imr-18350-1200mah-10a-2pcs/
EDIT: I searched a different way on the site and found them there.
I wonder why that is? But anyway I can put them in the cart to purchase, and shipping is only $2.99 which is less that what gearbest is charging me to ship a pair of the UltraFires, and a little over $3.00 less than amazon.
I would assume that the same battery being equipped with a protection circuit for a high drain cell would end up costing more since they have to add the board plus add more FET’s to the board to achieve higher currents.
While this is true moderator007, you may also already know that final product cost is largely driven by political reasons like perceived value and supply/demand. I do often find protected cells at lower prices versus unprotected ones.
I was just suggesting that if they didn’t add the protection circuit they could sale the battery cheaper and we could buy them cheaper.
A few years ago when I was build a battery pack for a hunting light, I needed a protection circuit in the pack. As the current capabilities of the circuit went up so did the price, may not be that way now. But the circuit is adding to the cost of the battery.
Ok I see then. For the Chinese manufactures I suppose adding the extra FET’s is probably in the cents not dollars range.
I’m happy these have the protection, and to have 18350’s that can deliver the same current as unprotected versions. Also as I said above, aside from these UltraFires, I’m not aware of any other High capacity/High discharge protected 18350’s.
