Wow, nice find with white LED! Thanks for posting.
I found several of this model when I was updating the list recently, it’s also made in the other head diameters like the 14xx/15xx (38mm, 50mm & 67mm). However I only could find them with IR and red/green emitters, no white LEDs so I didn’t add them to my list.
Yes I also thought they were very interesting! The 67mm one you linked is the only one on Aliexpress with a white XM-L emitter, there are a few sizes listed there with white Q5 and one with XRE, but looking deeper with google I also found a 38mm with white XM-L2. I’ll add these to my list in the OP.
Litesam E11 Z
750 Lumen Tactical Flashlight Zoomable
This is said to be the same as Fitorch P30Z but with diamond knurling, Litesam is Fitorch’s amazon exclusive line.
It’s a very well built flashlight and the beam is great at full zoom in and also good at full flood. The body style of the light somewhat reminds me of the Solarforce L2. It has a forward/momentary rear switch, and also has very good/aggressive knurling!
It does have a dark spot when zoomed in-between fully in and fully out, this is my first TIR zoomie so I wasn’t used to that (or aware of the characteristic)
Totally off-topic here (not about a zoomie) but your post got me poking around that Severe Cold shop, and this light is very intriguing to me. Even though I’m a big fan of knurling the light is appealing. I’m curious about the finish, (wondering if it’s clear anodize) also wondering if that’s a P60 drop-in.
It shows 14500 in one of the photos but everywhere in the description it shows 18650
EDIT: Lemon from Severe Cold replied and confirmed it indeed is 18650, but he didn’t answer about P60 dropin.
FWIW… A few months ago Amazon had that light available as a $5 add-on item. I tried to add one onto my order but it sold out. It was still popping up on their www site as recently as a month or so ago.
I am somehow attracted to zoomies, but I see some are missing from the list: Xtar WK007, Severe cold, Fenix FD41, Fenix FD40, Fenix FD45, Brinyte B168, Brinyte B158B, Fenix Fd65. I can’t yet decide whether I like the wide of the TIR lens more than the throw of the aspherics
BTW, has anybody been able to open Fenix FD40/41? I don’t quite like the 6500ish white, but I love the beam profiles.
Hi yasenf, the Xtar WK007, Fenix FD41, Brinyte B168, Brinyte B168B are all on the list, not sure why you’re not seeing them? (The list isn’t in any kind of order) Also the Odepro KL52 is on the list but now we can just get the 168B (same thing)
But yes those other 3 Fenix I didn’t list, thanks for pointing them out! I’ll add them as soon as possible.
The Severe Cold is showing “Sorry, this item is no longer available!” by the seller, but Argo bought one by asking, and I’ve contacted them and they said it’s available, (see posts above) However I’m waiting to see if they’re going to make the listing active again before I add it to the list so I can have a good link.
BTW, the photo you posted isn’t showing up for some reason.
Also you may have already seen this but I wanted to post this thread about the FD40 with a lot of photos and comparison to the Zeusray, Warsun X65 and Jax Z1. But I didn’t see anything mentioned about disassembly, I guess that one’s been around for a a while:
BTW the SevereCold reminded me slightly of this (P7.2) clone:
I didn’t add it to the list because it uses primary’s not Li-ion.
I think it has the same lens system as SevereCold?
The optics in the clones suck, they are far from as good as the real thing.
You can find a lot of tests and reviews on led lenser clones and none give the nice round spot with no spill and almost perfectly uniform wide-angle spill that the real TIR does.
Thanks for the heads up on the clones, do you know who else makes good “real” TIR zoomies? I’d like to try one. The MT10/MT14 do look interesting to me, although I bit pricey. I think those are the only Led Lenser zoomies that run on regular size Li-ion?
Are Coast flashlights still made by the same Mfg as Led Lenser? I have an older “Coast Led Lenser” (Non-zoomie)
I just received my first single emitter TIR zoomie, the Litesam E11Z (Re-branded FiTorch P30Z) it does have a nice round spot but the edges aren’t crisp like the square spots, also has a big dark donut hole at all in-between positions, which basically makes it a a two mode light, full flood or full throw.
The Coast TIRs, at least the one’s I’ve seen, make a combined spot+spill like a reflector light in the zoomed in position.
This is different from the spot-only led lenser TIR.
