See post #11
No thanks. It's a FryRay.
Who cares about the colour and frying driver, you use it for not more than 4 mins at a time. (TM11 would cut in at about 8-9 minutes). It's TM11 size!!
EDC?
Problem is that the TR-J12 5xXM-L is already an amazing flashlight. But this one has 4 x 18650 and it's 80 bucks.
Extreme runtime for 200-400 lumens...good enough. My experience is that other than for very low light work like visual astronomy work (with red filter), point zero X and few lumens usage is literally of no use in real life for most of us. Few lumens for going to the toilet use....
Wow. Not often does a clone come out that looks this good and tempting. I am eager to see a review or two on this thing!
Honestly I wasn't expecting a TM-11 clone, or at least not one that looked so similar in size with a side switch for that price range.
What i am also afraid is that DX would come out with one for 68 bucks. hehe....
I have the Solarforce L2P "Yellow", which is a lighter shade of the current Gold version. It looks ok actually...this one would be quite close.
Very tempted to pull the trigger. But I just purchased a bit of telescopes/eyepieces/accessories, and waiting for my wife to find out about that purchase!
Looks like Nitecore TM11 clone to me
This is made by Skyray, hopefully this will not be another "Fryray"... (like some members here mentioned about?). And I am curious about its current draw, 3A or above? Not?
2100, I care about the frying driver...
If frying drivers bother you and one does not have the discipline to run it under 3-4 minutes, then you'd need to go Nitecore TM11.... (thermally regulated). The issue is usually that the driver components/design are somewhat inefficient and as you know the drivers are not exactly heatsinked well. Boost drivers are the worst of the lot, lots of current + inefficiency. Coupled with the heat from triple XM-Ls plus lightweight light (not sufficient "heat mass"), operating in such conditions for > 5 hrs total is already very good.
In Indonesia during CNY, i actually gunned the Xtar S1 24 by 7, just kept feeding it with 18650s and recharging 24 x 7. 24 x 7 also was the operation mode for the UF-H2 and UF-H3. Very nice.
PS. Output was at the absolutely lowest, of course.
quality doesnt come cheap
Since I won't have to purchase another set of batteries and have on hand 4 Redilast 18650-2600's, I decided to place an order for this light. If something turns out to be wrong with the electronics, I don't know if it would be worth sending it back. In that case, I'll be depending on members of this forum to give me a hand helping me find a driver to make the repair myself. Thanks folks.
NICE!
Color kills it for me but would be a great candidate for a duracoat project . :) Here are some ideas: http://public.fotki.com/cmacclel/lights-1/duracoat/
Just ordered one.
Haven't bought a flashlight for more than two months, already thought I'd lost the flashaholic spirit, but this light gave it back.
If I don't like the driver, I'll replace it with NANJG105C plus two slave boards, I guess. I'll see how much space there is.
Nice! Even if the driver pocket is very shallow, with the size of the original driver you could probably lay 3 Nanjg drivers flat in a triangle.
dispatched!
Looks quite good, the word clone cannot be used.
At least it looks better than the DRY, that i'd have to admit!
Only thing going for the DRY is the WW and NW options.
Looks really nice to me. I have the original SR 3800 and it has been very robust. The later versions are where most of the problems occurred. I think as long as they dont try to figure out a way to turn it into a dropin configuration it will be good.
Let's not forget the awesome driver options. I wonder if one can cram the $15 KD driver in the King's gut ?
