@ alternety……… For the life of me I cannot understand what you find so difficult with this UI as it comes from the factory.
All you have to do is push the button & hold it till it is as bright as you want it & then quit holding the button down.
Then…. when you want to turn it off, click the button & it is off.
To me… this is not complicated at all. How much simplier could it possibly be?? Seriously??
Just how could that even be “”dumbed down”“??
And as far as it being a “disservice to people (random civilians)” and “dangerous in unskilled hands”…… that may be your opinion, which is just fine. But I doubt it is shared by very many people. (which is my opinion)
And anyone should have enough sense not to look into the ‘business end’ of a flashlight when they are turning it on and/or using it. IF they do not, they have no business using any flashlight.
I guess different strokes for different folks……. but, as I said above; I fail to see how this could be made much simplier than how it came from the factory.
When you want it ON…. push switch button & hold…. releasing button when desired brightness level is reached.
When you want to turn it OFF…. click the switch button. It is then OFF.
Alternaty a solution to your problem is to buy another flashlight that meets your needs. Put the q8 in a cabinet somewhere else so you can have it as a reminder to research a product to see if it meets your personal needs and requirements before you buy it. By the way, a flashlight hobbiest website who teams up with manufacturers to make advanced flashlights that the members of said website can purchase cheaply is probably not the place to buy an emergency flashlight that any child can use. Good luck finding the light that actually meets your needs, maybe try the sporting goods section of your local Walmart. Cheers!
I’ve had good success handing the Q8 over to noobies. They figure it out quickly, it’s a fantastic product. For easy access I still have my old Malkoff converted 2 D cell maglite, on/off - easy/peasy. It never seems to get used though. My daughter likes to go walkabout with the dog late at night. I have a 1000 lumin Nitecore MH20GT now which I leave out for her that has a mini-USB plug so she can charge it whenever it needs. She had once grabbed my Convoy C6 to shine on the guy she caught breaking into my truck at 3am. We both learned that in an emergency, having a tail on-off switch AND a side button for modes was not a good idea. She was unable to work the flashlight, but the good news was the guy wasn’t alerted and her phone call to the police resulted in his arrest.
I think Alternaty’s main “beef” with the Q8 is that while it’s “intuitive” to a certain point thereafter it rapidly can become nonintuitive. It’s an understandable complaint considering that the average public user of modern led flashlights have generally been pre-conditioned by the standard fare of on-off-high-click-medium-click-low-click-possible-strobe click.
The Q8 ain’t one of those lights to say the least. You really only get “intuitive” with it after you read the directions thoroughly and then practice with it a lot. It takes effort. It is NOT intuitively simple to use once you get much beyond the ramping up and down then just turn it off features. Again, I think that’s his point and he’s taking a bit of umbrage at those that make him perhaps feel a bit stupid. All these videos explaining how to better clearly interpret the fine print directions is a testament to that deal.
That said, his point to consider from a potential increased sales standpoint that an intuitive version and a nonintuitive version being offered is a valid one. To sum it all up: KISS vs let’s make it challenging. Who’s kidding who? The Q8 is ultimately challenging.
Clearly one may not know what they’re getting into until one actually gets into it. Complex things tend to do that. The Q8 is NOT necessarily simple to understand unless you know what the creators of it intended it to be.
A typical led flashlight was obviously never the original intent here. This is an upper grad-level light, man. I’m not saying anything profound here that hasn’t already been said. I’m just kinda defending the guy’s perspective.
Yup, the hard part of the Q8 is in not making it overly complicated on purpose.
Oh one other thing. If I had designed the Q8 UI in hindsight I probably would’ve had TWO factory default optional settings.
One default is the one ya got now.
The second default would’ve been the KISS option: Click-On get low, click again get Medium, click again get High, click 3 times anywhere in the cycle get Strobe click 4 times get moon. Or something to that effect.
If we had designed the Q8 as a light for dummies, I would change 2 things:
1)it would have internal charging, probably via a base, like your average electric kettle or tooth brush
2)it would have a turnable switch like the power/volume knob on old radio’s, turn it to switch on, turn further to ramp up.
Still a nice variant to consider having built, but complicated to design.
That. I keep thinking about new builds, but then I realize they won’t have an e-switch and Narsil/Andúril, and I lose interest. I need to find a good e-switch host, find a driver that will work with the cool firmware (and fit in said host), and start flashing drivers. Then I can mod or build again.
The first three people I gave the Q8 to play with ended pretty fast in configuration.
Since I have a standard introduction to the Q8, there were no more problems in handling the lamp.
I think it is not intuitive, more easy to get. But you can end up pretty fast in config/blinking if you only play arround.
Quick introduction for newbies or relatives:
- Don’t hold the button down for longer than 8 seconds! The lamp will enter configuration and starts wild blinking. Don’t push a button or you change things. In case handle it to a pro or search for reset in the cheat sheet.
- Don’t look in the working end!
- One click on, one click off.
Push the button and keep it holding for ramping. Rember to release within 8 seconds.
You never should have bought this light. It sounds like you would be better served with a 4xAA light, of which there are several nice ones. You’ll only get 1000 lumens from them, but that is more than enough for almost every purpose.
I suggest removing the batteries from your Q8 and never use it again. It can be very dangerous if not properly handled, including doing things such as installing batteries the wrong way around, or accidentally turning it on high when it’s close to something flammable.
The Q8 is meant for flashaholics, and people with prior experience with 18650 lights. A “random civilian” should not use this light. It’s safe if used with common sense, but that is often shown to be lacking.
Since Banggood sells this light to everybody it actually should have a safe mode for “random civilians”.
With a pass code protected configuration menu this could easily be achieved.
