Yup, the hard part of the Q8 is in not making it overly complicated on purpose.
Oh one other thing. If I had designed the Q8 UI in hindsight I probably wouldâve had TWO factory default optional settings.
One default is the one ya got now.
The second default wouldâve been the KISS option: Click-On get low, click again get Medium, click again get High, click 3 times anywhere in the cycle get Strobe click 4 times get moon. Or something to that effect.
If we had designed the Q8 as a light for dummies, I would change 2 things:
1)it would have internal charging, probably via a base, like your average electric kettle or tooth brush
2)it would have a turnable switch like the power/volume knob on old radioâs, turn it to switch on, turn further to ramp up.
Still a nice variant to consider having built, but complicated to design.
That. I keep thinking about new builds, but then I realize they wonât have an e-switch and Narsil/AndĂșril, and I lose interest. I need to find a good e-switch host, find a driver that will work with the cool firmware (and fit in said host), and start flashing drivers. Then I can mod or build again.
The first three people I gave the Q8 to play with ended pretty fast in configuration.
Since I have a standard introduction to the Q8, there were no more problems in handling the lamp.
I think it is not intuitive, more easy to get. But you can end up pretty fast in config/blinking if you only play arround.
Quick introduction for newbies or relatives:
- Donât hold the button down for longer than 8 seconds! The lamp will enter configuration and starts wild blinking. Donât push a button or you change things. In case handle it to a pro or search for reset in the cheat sheet.
- Donât look in the working end!
- One click on, one click off.
Push the button and keep it holding for ramping. Rember to release within 8 seconds.
You never should have bought this light. It sounds like you would be better served with a 4xAA light, of which there are several nice ones. Youâll only get 1000 lumens from them, but that is more than enough for almost every purpose.
I suggest removing the batteries from your Q8 and never use it again. It can be very dangerous if not properly handled, including doing things such as installing batteries the wrong way around, or accidentally turning it on high when itâs close to something flammable.
The Q8 is meant for flashaholics, and people with prior experience with 18650 lights. A ârandom civilianâ should not use this light. Itâs safe if used with common sense, but that is often shown to be lacking.
Since Banggood sells this light to everybody it actually should have a safe mode for ârandom civiliansâ.
With a pass code protected configuration menu this could easily be achieved.
Câmon, a cattle prod? A cattle prod is just like your typical flashlight within reasonable public consumer expectations of what a typical flashlight does? Most flashlights typically donât shock the living sh*t out of you even if you âmishandleâ one, right? Or can kill you if you have a pace maker, right?
Would you leave a cattle prod just laying about your home around people that donât realize what it can do? Do you really think a live cattle prod and a live Q8 on a kitchen table unsupervised around kids is a valid argument for debateable comparison here?
Whatever Banggood does or doesnât do when they sell cattle prods is one thing. Reasonably expecting Banggood warning the public about flashlights to the extent that a cattle prod warrants is another thing. I donât know but maybe thereâs no legal requirement to warn about anything that Banggood sells within Chinaâs consumer protection laws for items of this nature. Basically what Iâm saying is that if you buy a cattle prod Banggood has a reasonable expectation that you already really know what youâre dealing with there.
Now if youâre talking about a new just hit the general consumer market high power laser that goes for only $5, will burn a hole through drywall, and looks like a flashlight, yeah Iâd think Banggood would have some extra responsibility to make an extra effort to warn their unsuspecting customers random or not of this new productâs untypical hazards. I would hope so.
The point from previous comments that from Banggoodâs perspective a Q8 should warrant a big deal warning OTOH doesnât fly either so your point is well taken but the comparison to a cattle prod here is where I lose the argumentâs valid connection.
Iâd really like to see drivers designed to use the little DIP switches.
4 or 8 switches on a small board gives the option of a whole lot (2 to the power _) of settings.
Unfortunately not. If you want to configure unrelated configuration options (like strobe yes/no, ramping yes/no, number of modes and so on), you need at least 1 switch per option. But actually you could use a single switch to allow/forbid configuration via UI.
Still the easiest way without hardware modification is using a passphrase to protect configuration. In my momentary firmware I lock advanced configuration options with a simple 3 digit passcode: for instance âclick-pause-click-click-pause-click-click-clickâ if the pre-configured passphrase is 123.
My point is that if youâre buying from China, donât expect the same consumer safety standards/warnings that you get in North America or Europe. Do your own research to determine how to safely use whatever you buy overseas, whether it be a cattle prod or a high-power flashlight.
