IMO I think the EDC05 has the best look to it. I like the design. It’s almost like the barrel of a gun. I would like to see the EDC05 get the bugs worked out as I think it could be one good light. Having that ability to use a protected cell offers good flexibility. I like the Manker E11 too. I’ve never owned one though. Perhapse in the near future if the Manker T01 II impresses me once I get them.
well, looks aint everything
Between the Manker E11 and the Lumintop EDC05, it seems like maybe the Manker version is more reliable, it also costs less
I have no dog in the race, I have lights from both brands that I like (I dont have either brand in AA myself)
with the Manker A01 vs Astrolux E01 I also think its the Manker version that is more desireable, although in this case it costs a bit more
I dont know much about the Utorch UT01 AA option. I do have an AA Thorfire TK05 I got for free, in exchange for a review. but I hardly ever use Cool White lights. Im a Nichia nut.
When I read about these XP-L lights, or XPG3 in the case of the Thorfire TK05, my mind immediately goes to thinking it would take a Nichia swap. While the XM-L lights dont allow me that fantasy.
at the end of the day, whatever gets you through is good, even if that means were guinea pigs for Asian battery tube sales
enjoy whichever one turns on for you the best
Is there a thread on these driver issues you can point to?
I have one of these coming from GB that should be here any day and I want to know what to look for.
Thanks!
read post 47, and the other posts in this thread
I also did a search for you:
more threads about the EDC05, maybe read through them to see what else is being said about it
http://budgetlightforum.com/search?q_as=LuminTop%20EDC05
Post #47 just sounded like a bad light, and I already read those other threads. In fact some of them praised the Lumintop driver as being good, which is why I asked my question.
So, I’ll wait for sovereignknight’s response, thank you very much.
There is my post,
I was in talks with a Lumintop representative and they are aware of a driver issue that needs to be sorted out.
I’d like to add my third light has been working fine so far, but I mainly stick to the Eneloop Pro in it.
I got my EDC05 yesterday. Apparently I ordered from BG not GB. Hard to remember when it shows up a month later. Whatever.
More importantly, no issues so far. Used a protected Sanyo (EVVA) 14500 and an Eneloop and ran it through its paces. Programmed the modes to the levels I like, clicked it on/off a few hundred times. Let it run on turbo for several minutes.
Time will tell if the driver holds up, but the features, build quality and form factor are really nice. Fingers crossed.
I wasn’t aware the EDC05 was programmable. How was this achieved?
Programmable = Configurable
EDC05 has no programmable modes according to research.
It’s done the same way as the UT01 or E11.
I’ve tried this but the modes on the EDC05 are different. There is no program mode, or consistent turbo.
Consistent un-timed turbo mode is Strobe. The next mode after Strobe is suppose to be a battery check but it is a SOS mode.
I fail to see how the EDC05 is the same as the Utorch or Manker with programmable modes. I’m unable to do this with my light.
FWIW…. my EDC05 is programmable. Its programmed just like the manker E11 and Utorch UT01.
You have to engage the program mode capability though. It does not come from the factory with it engaged.
From OFF, Long press the button for 6-7 seconds it will blink once to indicate the program mode is not engaged. Long press again (6-7s) and it will blink twice to indicate program mode is engaged. So you can go back and forth with 6-7 second long presses.
With program mode not engaged (one blink) the modes go Strobe-SOS-Beacon (repeat). Just as you show in your video.
There appears to be a lot of variation though, lot of EDC05 inconsistencies. Particularly with lower voltage cell chemistries. My findings are with 14500-4.2V. I have also found the most consistent performance is with 14500.
Interesting, I’ll have to try this. I wish this step was also demonstrated in the video.
The 14500 I use is an EVVA Sanyo 800mAh with a Seiko protection circuit.
I’ll try this and report if it was successful.
This worked for me! Thank you! That vital little piece of information was missing!
Awesome!!!
That little piece of “missing” information was literally the second post in the link I gave. SMH.
Ahk! I see it. /Facepalm
I’d like to report that my one and only remaining EDC05 now developed the issue where I have to disconnect the head and twist it back to turn it on.
There’s definitely quality control issues going on with the EDC05. So far, Manker and Lumintop have struck out with me. It’s time for the Zebras to step up to the plate as they arrived today.
I’ve received the Zebralight SC5w MK II today. My overall impression is that they are pretty nice. Out of the box, both lights work properly in all modes. There was no switch problems or lousy connections.
I was afraid that the tint @ 4500k would not be to my liking, however it is acceptable.
The SC5W MK II is quite a bit shorter than the Lumintop EDC05.
The head is obviously bigger than the EDC05.
Knurling is pretty fine but it provide excellent grip.
The clip is pretty stiff. It’s ok, but I’m not 100% crazy about it’s design.
The recessed button is fantastic. It ensures to protect from accidental activation in the pocket. The switch provides a solid feel and produces a very satisfying “click”. Observing the head reveals it has fins for heat dissipation. The LED star is bonded to the uni body frame so that’s a no go for moders, however I’m completely fine with that as I don’t need to worry about thermal paste breakdown.
This light doesn’t use traditional springs. It uses gold plated Pogo pins in the tail cap. This provides a great connection and reduces resistance, not to mention allows for the light to be more compact.
The positive connection uses a sort of “Omega” style gold plated connection point. I’ve never seen this before, however from a design standpoint it may be intended for better solid battery contact.
Finally the tint! It is 4500k. I was afraid I would not like it as I’m more of a 5700-5500-5000k kinda guy. I feel I can accept it though I doubt I’d go anything lower than that. I am glad I did not buy the SC5c MK II as I don’t think I could stomach the yellow produced from that, as well as reports of a green tint mixed in. Yuck! For the 4500k version, I can live with a 83-87 CRI rating.
