The thing that catches my eye about it is that it has an LED display for voltage & current, not an LCD one. I like that, because Iâm legally blind, and some LCDs have such low contrast or poor view angles that I find them almost impossible to read. I might order a couple after the Chinese New Year chaos is over
Probably not. After the one hour load test I would not be able to write anything for days
In reality I would have to do some setup with a speed controlled motor to test it and start plotting power vs RPM. It could be fun, but it would take a lot of time and I would have to manufacturer some of the test equipment first.
IKEA STORHĂGEN
Battery charger with storage When batteries are fully charged, this battery charger switches to stand-by charging so that you can store your batteries in the charger if not using immediately. When batteries are fully charged, this battery charger switches to stand-by charging so that you can store your batteries in the charger if not using immediately.
As I noted in the other post, for some odd reason, XTAR doesnât market an English version of this charger; they only do so under their lesser-known (unknown?) Allmaybe brand.
So itâs only available directly from their Aliexpress or eBay US. stores.
I can try to help persuade them to send a review unit, as I only discovered this model after contacting XTAR directly inquiring about the English version that I didnât know existed at the time.
