What did you mod today?
Used Sugru (an uncured Silicone from the UK) to make a silicone sleeve on my Emisar D1s. Had the blue Sugru left over on another project and had to use it somewhere, rolled it out and wrapped it around the tube of the D1s and rolled it like a pastry roller on the bathroom counter (little bit of water helped keep it from sticking to the counter and roll out smooth)
Nice move Dale. This is the kind of thing that this light needs to keep a grip on it. Still wish it had a hole for a lanyard. I’d really hate to drop it in the river.
I wanted to use my Skilhunt H03 shorty with Andúril firmware So I ordered 22DD-m fet+1x7135 driver board which designed by DEL and grinded down to 21mm diameter to fit the H03. Built the driver:
Removed stock driver:
Test run:
I couldn’t make the switch indicator led run so I soldered two blue leds between switch legs and they draw 0,2mA current so it is good for me. They are always on except when button is presed. And don’t mess with the firmware at all. On the left it is the stock red led. Maybe later I will use it for something.
I got my M2 quad together (I stripped the black anno off to the bare aluminum). It’s running LED4Power 12A driver, 4x Luxeon V on his MOSLED board, and his lighted tail switch. Spacer is from Kiriba-ru. First time using any parts from either vendor, impressed with both!
Ceiling bounce numbers:
Constant Current 12A setting: 4,000 lm
Direct Drive setting: 5,385 lm (@ turn on)
Moon is just a little brighter than my D4 Nichia.
It does 4,000 lm for about ~75 seconds before stepping down to 1,000 lm. I let it run 5m total and it never stepped down from 1,000 lm but the body was not comfortable to hold at this point. Somehow the entire body transfers heat, not just the head/copper spacer.
Skilhunt H03 Shorty with FET+1x7135 and Andúril with blue lighted switch
Nice mods above!
I have done a C8F mod today but flickr does not want to upload. If that works again I will post a what did you mod yesterday.
Thanks!
Just finished my C8F too. I disassembled completely three times because of one faulty led.
Now it works. Tomorrow when I get home I will measure the output.
FourSevens Atom Triple XP-L HI.
I reworked my keyring flashlight with a reverse tail clicky switch.
The detachable magnetic holder is made from an old steel strike bezel which has a through plunger so the lights clicky switch can be operated whilst still attached to the holder 8^)
Also changed the driver to an LD-4 3A with external NTC.
Triple XP-L HI v2 1A on 16mm Noctigon
Carclo 10507 TIR optic
LD-4 3A driver with thermal regulation
Reverse clicky tail switch
Cyan GITD tail ring
Brushed stainless steel
Custom made magnetic keyring holder with through plunger switch
Green 6mm x 1.5mm tritium vial
Max - 1740lm OTF
56mm x 19mm
Weight - 52g with 16340 cell
My other FourSeven's Tail Clicky lights
Also rebuilt my Olight TC10 Ti with an XP-L HI v2 5D on 16mm Noctigon, new OP reflector and GITD switch.
Around 1100lm OTF with the FET driver.
Some beautiful mods again, CRX! Especially I like that you often mod Foursevens lights, love them but ever only bought one (a warm high CRI mini-AA).
And Flickr upload works again so here is yesterday’s mod, a Sofirn C8F host with:
*corrected a hole in the ledboard to compensate for the sloppy manufacturing work on the reflector (screw hole in the wrong position)
*reflowed three XP-L2 V3 4000K 80 CRI leds (from Mouser)
*used 18 AWG ledwires, but still the current is limited by them because the way the head is build, they need to be long.
*Lexel’s 17mm 3-channel e-switch Narsil driver, with a reversed spring for battery contact, the led+ wire (through the enlarged to 2.5mm hole in the driver) soldered to the top of the spring. The 7135 chips on the battery side had the corners filed off plus the brass driver ring was bevelled on the inside to make the ring fit on top of the chips.
*lowered the resistors on the switchboard from 33K to 4.7K, and the green leds for yellow ones. Swapped the shallow dark switch cover for a raised clear one (spare switch-cover from a Q8)
*did a tail-spring bypass with 18AWG silicon wire.
*sanded the ears off the tail and Foy-bezeled the bezel.
The current and output was a bit less than expected: 15 amps and 3500 lumen on a charged 30Q after 30 seconds (output is pretty stable so the leds are well heatsinked), I hoped for 4200. I blame that on the rather long ledwires that this host requires, all other connections in this mod are very beefy. The beam is good with a clear hotspot, as to be expected from this host, I did not measure throw. The tint is very nice, the hotspot does have the yellow-ish corona that we came to love with all new Cree leds, but with the 80CRI leds (both 5000K and 4000K) the yellow is not scary greenish but a very acceptable soft yellow. The yellow switch leds light up nice and bright and use 0.7 mA when the light is off (almost half a year to drain a 30Q).
I like the yellow lighted switch & Foy bezel :+1:
Nice stuff! I have six of these hosts waiting for my new driver design on the way. Do you have the exact order code to the LEDs on mouser? I don’t understand Mouser’s search engine. Let’s say I want to see what XP-L2 LEDs they have. I can’t select XP-L2. I select all other stuff, but not narrow it down to XP-L2. How do you do that?
Cree order code: XPLBWT-00-0000-000HV340G
https://mouser.com/ProductDetail/941-XPLBWT000HV340G
I’m not good at Mouser’s search engine, it can not find XP-L2 and leaves products out that are clearly within the filters that I use.
Thanks. You don’t have an answer to the search question though?
Just edited the post, now I did :slight_smile:
Thanks again. I guess I’m not the only one having difficulties with Mouser search.
What I remember is that I managed to get the XP-L2’s listed separately from the XP-L (dunno how I did it), they have just 11 XP-L2’s listed, and then went through them one by one for the specs. But only 2 of them have complete specs on the Mouser site so I looked the product numbers up in the datasheet to check the specs for the other 9 :person_facepalming:
Mouser XPL2
Maybe i’m oversimplifying this but if you type XPLBWT then query. Then check in stock, then hit filter. You get the above URL. You could also filter by Cut Tape to remove the stars if you want.
Still, djozz is right that they are missing all the stats so you will have to open the data sheet and CTRL+F for those full part numbers to see exactly what bin/tint/etc you are really seeing.
I put my new little Thorfire TK-05 on a small diet. :slight_smile:
This small 14500 sized light doesn’t need tactical crenelations, gone… nor does it need a lanyard… wings gone. So maybe now it won’t snag things with the little wings on the tail cap when in my pocket.
As it turns out, I also built an FET+1 driver for it with Anduril. So the TK is for ToyKeeper and the 05 is for (true stuff right here!) my fifth iteration of Anduril. I was thinking this when I cut in 5 visible rings on the tail cap. Should have laid it out more carefully (actually should have laid it out, cut it on the fly by eye) I guess but oh well, bulls-eye works.
Nichia NF2W757GT-F1 Rfc00 5000k
16mm XML
AA driver
Low:7mA
Mid:100mA
High:500mA
Left Rfc00 5000K,Right XPG3 3000K 90CRI
Same driver high mode
