FYI, I have a Sanyo protected (EVVA) 14500 cell that is 52.3mm long, and it does not work in my red SP10B either. My shorter unprotected Sanyo cell works fine.
Received my 2 SP10Bs: red and blue, as well and 1 charger and battery.
The Sofirn battery holds 848 mAh - fast tested with Liitokala Lii-500.
They look nice and cute.
The red one has a dent in the threads.
The anodization looks a bit thin.
Tested with 2300 mAh Ni-Mh battery from Lidl (glitter colored): 1 h 40 min on medium until it stopped emitting light.
Will follow with the Soshine white/yellow 900 mAh.
Both of them have the little bug in the UI that actually I find useful: Long press form OFF puts the light in the memorised mode (apart MAX and Strobe). Short press from OFF puts the light in Moonlight.
It ain’t a bug It is a “standard spec” on this new driver / UI, and it has been reported on this or in other thread related to the SP10A or B
Pretty nice, we can access at least 4 different modes from OFF (ML ; last used mode if not ML; Turbo; Strobe)
