Frankly, sometimes I’m just throwing ideas around to see if they resonate. This is one of the cases.
We know that some light makers do light engines like that.
But all that I’ve seen use non-DTP boards for that.
It seems to me that the led4power tech would be better in this regard.
Such use has a number of benefits, but also creates some problems.
And even if it makes technical sense, for almost all hosts it won’t be significantly better than separate board because they already have space for such board. But maybe there are benefits other than size? Or maybe there’s a market that I don’t see?
I’m curious what people, especially led4power, think about it.
It definitely has it’s use in some lights. Not sure about the market value for someone to make them though, to me it seems more a custom job for specific lights.
Shortly, yes, light engines are very convenient to use in theory, everything is on one pcb and there are no thermal issues. But they have quite few disadvantages:
Light engines are pretty much limited to triples and quads, it's not possible to make light engine on standard single LED on 20mm pcb,at least not with lights which use reflector,
LEDs become outdated pretty fast these days,with light engine configuration you are stuck with default leds, and for most modders changing 3-4 LEDs on very tightly populated pcb would be too challenging,
For each type of led (3535,4040...), for every number of leds (3 or 4) there is need for different pcb design, which complicates assembly and increases initial cost,
With bigger leds like 4040 there is very little space for all driver components on typ. 20mm 3x or 4x PCB,
Central hole for wires on 20mm light engine is generally not possible because this is most useful area for bigger driver components - this means you can't use available triple/quad spacers or lights without drilling holes for wires closer to edge of spacer/flashlight pill.
Generally speaking standard drivers/LED DTP PCBs combination have only one disadvantage (IHMO) vs. light engines and that is more limited heat dissipation,regardless of driver type. LD-B4 is something between normal driver and light engine, its disadvantage is larger number of driver<->LEDPCB wires and need for special MCPCB (mosX,mosDTP).
So after some thinking,I have another idea around which I will build some future drivers, shortly they will be simple to use just like "normal" drivers (two leds wires,optional temp. sense wire,normal DTP), and have thermal dissipation capability close to LD-B4/mosX combination, so they will be perfect for most common builds (single LED,triples,quads). LD-B4-like drivers will still be there for very high power builds.
ILC-0 RGB color changing module on sale: ILC-0 RGB
I tried it with BLF A6 driver and it works nicely, except current draw is higher (2-3mA), whit different bleeder value it should be possible to reduce it. Anyway,battery is safe from overdischarge since LVP kicks in at <3V (1.2uA sleep current).
^ the BLF-A6 driver as it comes from Banggood does not have a bleeder resistor (while the X5/X6 driver does have one, 470 Ohm), which value did you use and with what led that works well?
My experience is also that the BLF-A6 driver is very tolerant for the lighted tail with varying led configurations and bleeder resistor values (unlike the X5/X6 driver which is extremely finicky!), it is just that l4p’s post above suggests a standard bleeder value for this driver while stock there is no bleeder at all, hence the question.
Sorry for late reply, this driver has 470Ohm bleeder, I didn't even try to connect LED or see how modes are affected, point of test was to check if it works with regular resistor bleeder, and it does,but in combination with driver input caps that prevent rgb leds to stuck in red mode.
I have an idea for an addition to your shop: The Osram LE UW Q8WP is basically a bigger version of the popular Osram Black Flat. It reaches the same luminance at maximum current, but is 80% larger, so the resulting hotspot is 80% larger and it produces 80% more lumens. It also does away with the three biggest downsides of the Osram Black Flat:
The central solder pad is now electrically neutral
The solder profile matches that of XP-LEDs (The Black Flat is smaller and doesn't center itself well)
The Vf is much lower
It has a new downside though: the die is not centered on the package. It is shifted slightly in one direction. Can you envision offering a real copper (one piece) dtp-pcb specifically for this LED where the die is in the center of the pcb? This way the LED could be easily centered like other LEDs and we will have brighter ultra throwers!
I think quite a few people would be interested. You could do a poll to get an idea. I would be in for at least 5, maybe up to 10.
That anna makes me trigger happy :heart_eyes:
Especially if Sofirn makes 21700 C8F that accepts MCPCB for it. I can already see 7 Vees with 30T :innocent:
Decided that I need to upgrade my convoy L2.
So just ordered a luxeon V on a MosDTP board together with a LD-B4 (set at 9A) and the ILC-1.
To be honest I forgot the check if the ILC-1 will fit in a L2 (first ‘new’ version, 17mm driver) but should fit right?
Otherwise I will be ordering a S2…
Could you please check brass retaining ring diameter on L2 tailcap? If it's ~19mm, then inner tailcap diameter should be ~18mm, which is the same as C8,S2... and ILC-1 should fit.
The switch board diameter is the same as the convoy C8. The dimensions of the retaining ring are not exactly the same, it’s 20.7mm on the L2 versus 18.8 on the C8.
So it’s a little bit bigger but I think that shouldn’t be a huge problem.
