Talk about future projects and donation topic
The highest I’ve seen available is 4800mAh, which is lower power density than a 3500mAh 18650.
Also 26650s still have much more capacity than a 21700, so unless the goal is a super compact flashlight, if you care about runtime you will go with 26650 over 21700.
If you care about power density more than runtime then you would get an 18650.
I looked for 2 fairly new cells with the same continous discharge rates in order to make it as comparable as possible. Apples to apples, so to speak.
Samsung 48G – 4800mah 10A
This 21700 cell has a volume of 24.25mm3.
This equates to 198mah/mm3
LG MJ1 – 3400mah 10A
This 18650 cell has a volume of 16.54mm3.
This equates to 205mah/mm3
So they are pretty much the same – power density wise. The 21700 is about 47% bigger and has about 41% higher capacify. It’s not an exact scale up, but almost.
It seems Tesla is predicting their new 21700 will have a capacity of 5700-6000mah! I have not seen any batteries with that much capacity. Not yet, at least.
If this turns out to be true, then the power density will definetly exceed the 18650.
So far, I really like this quote from John Peterson.
“Batteries are chemistry in a can and changing the size of the can does not change the energy density or cost of the chemistry inside the can.”
In looking at my older quote above, I checked HKJ’s review of the MJ1 3500mah and it seems it’s capacity is closer to 3200mah and it’s max continous discharge is 7A.
His test of the 48G shows a capacity of around 4650mah and 10A continous.
These may not be the ideal batteries for comparison, but the power density is pretty much the same.
48G - 192mah/mm3
MJ1 - 193mah/mm3
OK. I see that these proposals were not taken quite like I meant them to be.
They were meant to serve 2 purposes:
  • act as showcase of a certain construction
  • be actual, direct proposals
I see that they are seen only as the latter. I’d like to explain the former now.
My main driver when drawing those lights was the goal of having lights that are high-quality, small, powerful, efficient, feature-rich. And cheap.
Do these lights deliver?
Yes and no.
Efficient? They won’t chase Zebras.
Cheap? Not. But not expensive either.
Feature rich? Smart-light makers beg to differ.
Powerful? A mere pop can light delivers way more.
Small? 10180 collectors will laugh.
High quality? BLF has a good track record so far.
Each of the qualities mentioned is relative. But I believe their combination is unprecedented.
Efficient? A bit more than the current BLF lights.
Cheap? There is nothing inherently expensive in those lights. Though features do add cost. Still, I believe the costliest part is R&D. Which is a part of the reason why I drew a family of lights - some costs are shared.
Feature-rich? Charging becomes common. Powerbank is a natural extension, but still rare. Firmware features? BLF shines here.
Powerful? There is literally nothing on the market to challenge them on performance-to-size.
Small? Few lights offer better battery-to-body-size. And all of them sacrifice both features and performance for that.
The key reason why they can pack so much is so little space is a combination of:
  1. LD4/TC style driver
  • delivers lots of current
  • delivers lots of regulated current
  • takes little board space
  • has no high components
  • is fairly inexpensive
  • is slightly more efficient than other linear/linear+FET drivers. Little less than induction based ones. High-vf LEDs help efficiency.
2. Driver integrated with LED MCPCB
3. Button and magnetic charging port in the front part of the head
That’s it. Every other decision I made when drawing those lights is not a key one.
Though some further decisions seem to come naturally from this:
  1. Unibody….better heat transfer. Why not?
  2. You need quite large MCPCB to fit all the components. This means that the head will have much larger diameter than 18650 battery. Therefore I believe going smaller than 21 mm diameter doesn’t really make sense. But going up, to 26650, to 32650, to 4*18650 is just as fine with me.
I simply picked the smallest that I believe was good.
But you said 21700 is not so good at the moment. Is it really?
The top of the line 18650 are actually like 3200 mAh at reasonable current (3A to be precise).
The top of the line 21700 are actually like 4600 mAh at reasonable current (3A to be precise).
The top of the line 26650 are actually like 5600 mAh at reasonable current (3A to be precise).
Yes, I do view them as good. Add to that high-current cells like 30T or 40T for those wanting more fun and it becomes very good. By the time the project is done, they should improve further (f.e. Sony is out of the game still).
21350? It is also a bit of why-not decision meant to increase the potential market to include people who want to go smaller. Anyway, it’s not a key choice.
Dedoming? Shaving domes by the thousand is not really expensive. Shaved LH351D shouldn’t cost more than stock XP-L HI. In fact I expect it to cost significantly less. And anyway, it’s not a key choice.
Magnetic connector? Does add some cost. It is a key choice unless we go further up in size.
Agro, your driver/mcpcb idea is what made me loose interest in your design. It just seems to not make any sense.
Interesting. Could you elaborate on that?
Heat is bad for electronics.
Plus, how can I swap in a new driver with NarsilM on it? Lol
Yes. But what I started with was the concept of the light engine and I validated it with noone but the highest expert on LD4/TC drivers we have on BLF. Led4Power. Only then I started having ideas of making BLF lights with them.
I assume it can be done to work.
Indeed, modifiability is severely reduced with such technique. You can flash different firmware. You can swap LEDs to others with same or very similar pad layout. That’s largely it.
All of that to improve size.
Is it worth it? For me - definitely. But I’m not surprised to see a different opinion. Actually I would be shocked if everyone agreed. :wink:
I think small is over rated. I find my DQG tiny 7x to be too short. When I hold it, my pinkie and ring finger hang off the back. I don’t like that.
Plus I’m not a fan of tir lenses. They are no good for walking at night.
This is why I have no interest in your design and other similar designs. I just have no use for it. Sorry.
That’s my excuse for not talking about it.
Surely that’s not the reason for everyone here to not talk about it.
It’s still good to know it. Thank you. I really appreciate what you said. Because the fact that you said it means that you care.
Frankly, the silence was depressing. I far prefer negative feedback to nothing.
Agro, please don’t be discouraged from posting your ideas here, in spite of what some may say (or not, as the case may be). I am one of the ‘silent’ followers here. Besides, this is BLF and there is nothing wrong with you posting to this thread. You haven’t hijacked anything just because others don’t contribute ideas of their own.
Jason, I disagree with you about TIR lenses. I find if they’re done well, they give me exactly the beam profile I like for walking in my neighborhood at night. Olight S1A is a good example.
I love to see the new ideas, but I find it hard to extrapolate the small images into full products. It’s hard to see how your design is more compact than anything else with those.
You’re among the few who actually expressed attention. And, what’s more, gratitude. This has not escaped me.
Your previous post was a light in the dark. Thank you David.
Thank you too. I have seen these concerns before. Your post reinforces them. I don’t present my ideas as well as I should. I should improve.
I will try………but if anything comes out of it, we’ll all see……….or not. I don’t feel strong enough to learn CAD now. But I’ll try anyway.
This thread started out good, kind of a research area for new project ideas led by someone willing to make some of those projects happen. However, I get the impression it has become something else — a wishing well, a grave for people to toss ideas into, /dev/null.
Maybe people are still waiting for their BLF GT, maybe they saw the mess that happened and aren’t interested in BLF custom projects, maybe they are out of money, who knows.
Half the people who ran the BLF projects aren’t active anymore.
Posted this in the lantern thread, but I’d really like to see a microlantern for use in tents that’s ultralight.
Something like 1 x AAA or 1 x AA, 2700k temperature, very long runtime at 0.5 - 3 lumens
This^
The BLF GT was a great project and produced a great flashlight, but the execution at the most critical times was unfortuneatly shall we say, a bit trying (not from the fault of any of those who stepped up in a storm of issues, hat’s off to all who made it happen, it was just not great to have things bouncing a thousand directions all at once)
To the point of I think a lot of members are at this time saying, the last thing we need now is a new project.
It was a project that became as they say “Became a life of it’s own” and it claimed victims of team members and BLF members at large, the forum has changed since this experiment for better or worse, it is what it is.
JMHO
Later,
Keith
Maybe no more gigantic lights? That is the reason for all those issues.
If a BLF project light is normal sized things should be a lot better. The next BLF light coming out is the FW3A. Let’s see how that goes.
A small note, I don’t think it claimed any team members. If you are thinking of the Miller leaving, that was due to his illness and personal life needing his attention. Plus other people stepped up to fill in his role.
Was there a different team member you were thinking of?
