Just got mine from Amazon .com, it came from Texas USA to London United Kingdom.
I did not want it shipped form anywhere else.4 Days to UK with priority shipping, OK I paid over the odds $117 with taxes and duty.
I have to say I am amazed every time I fire it up. I will be doing a few mods tail spring bypass, double A R Coated lens, brass screws, but to be honest it does not need it.
At times it is too bright. Well done to everyone involved in this project.
My switch won’t turn the light off when I click it. Usually takes one or a few clicks. Can I pay someone to do everything in lazy’s Thread and install new brass screws? I started the list in October after he posted it and I’m just now finished reading it let alone attempting it.
Hi guys, my Q8 is dead :confounded: HELP!
I bought it in January this year at Banggood, used it a few times, mostly it was laying around
but I was super happy with that hell of a flashlight until yesterday… fail… it wont turn ON anymore.
I have turned it ON yesterday for a short time, about 30 sec and felt that the flashlight was warmer than usually on the front.
After turning OFF it wont turn ON anymore.
Even if I pull out the batteries (Samsung INR18650-30Q) and put them back in, the flashlight usually “blinked”
once when it got power from the batteries or the button was glowing, now it is totally dark.
The driver board visually looks OK, nothing seems to be burnt, the bottom spring plate is OK too as far as I can see.
What else can I check?
The LiIons are charged 4V each
Can someone point me to the process on how to get a new Q8 switch? I don’t mind paying for it! Mine has kept on flickering and just want to get a new one. Thanks!
The Miller was taking care of that when switches from the first batch failed, but I do not think there is another way now.
But I just read that the Sofirn Aliexpress store started selling Q8 drivers, perhaps you could ask them for spare switchboards too?
When you said you looked at the driver, did you remove the retaining ring and look at the other side of the driver?
You can eliminate any potential problems with the battery tube by holding your battery positive directly to the Brass Ring and then running a wire from the battery negative to the driver retaining ring. Try that.
