Got it today. Neat little lantern. UI takes a bit getting used to.
Glad to see my unprotected button top cells work fine in it.
Also, when the light is on (either white or warm light), long press (2 seconds) of the red light button turns the light off without having to cycle through red light.
Let’s see if I can use this as a companion light next to the computer in the evening; I often feel it’s a bit on the dark side and I sure don’t mind a bit of warm white lumens. :sunglasses:
This is great, I’m stoked alright!
I bought one… I think wast the first… lol… but then I was so impressed I ordered a second one!
I think it is the best lantern on the market for the money! Also it can run off of usb power only with no battery which is a huge plus! I also tested the battery and it tested a little higher than advertised. The ability to set a custom tint is fantastic!
The Fenix CL25R lantern and clones can run off usb only as well. However, the CL25R can only run at about 25 or 30% power, where this Zanflare T1 can run at about 75% power using usb only. Most all flashlights with a usb port can run off usb power.
