I know... I know...
I know... I know...
Your Welcome
Hi, I am new to this forum.
I just sold my Dry to my Bro-in-Law, cuz he had to have it. Not because I did not like it. For the money it is likely the best small bright light out there
I just ordered the Electrolumens Buiser which is on sale for about $149. It uses a 26650 (might have one more zero) battery and he rates it at 3000 lumens.
I should get my Bruiser in a few days and will give a comparison. I also own the TK70 and the TM11. I found both to put out noticeably more light than the Dry (not saying the Dry is not amazing, all things considered).
I don't think the TK70 is a comparable light because it truly lights up the inside of a dark 2 story chimney (I inspect fireplaces). The TM11 does a good job and the Dry is acceptable, but the TM11 does a noticeably better job than the Dry. This holds true for my bounce tests as well.
One thing I really liked about the Dry is the reverse clicky at the back (the TM has an electronic type on off switch on the side) which means its less convenient to turn on and off.
I wont be able to do a side by side since I no longer have the Dry but I can compare it to the TM11.
I will put a quick review here when I get it. I won't be doing beam shots since I am too lazy (lets be honest) to set it all up. Actually, if the Bruiser blows it won't really matter.
I also ordered his EDC which is claimed at 1000 lumens and uses an 18650 battery, it's on sale for $99.
He seems like a real good guy (the owner) and responds quickly to emails. No, I do not work for him. But I love my lights and if I find a good one (especially if it is made is US) then I will promote it.
When I ordered my Dry I ordered an extra battery holder and their holster. I advise the extra holder since the first one I touched fell apart and the spring broke off (all fixable). The $5 holster is inexpensive but it will not last if you are like me and use your lights all the time (placing it in and out of the holster a lot). So if you want a holster, order 3 and certainly order another bat holder if you are serious about using the light.
Welcome to the gang, John! You will fit right in with the rest of us crazies.
Looking forward to your review of the Bruiser.
Johnny
Now that I finally have my DRY in hand, I can offer a couple of thoughts. Right now my primary thought is how when I first got the DRY I was blown away by its brightness. That is until I broke out my TR-3T6 and found the 3T6 to be every bit its equal.
Unable to find this acceptable based on all I had heard of the DRY, I decided to test its draw at the tailcap. In the DRY I had 3 fresh charged TF 2600 Flames and was stunned it was only pulling 2.6A at the tail. I then opened the 3T6 and yanked the Panasonics in it that I got from Reverend Jim and put them into the DRY and put the TF Flames into the 3T6. Fired them both up again side-by-side and was relieved to see the DRY performing a little better than it was. I tested the draw on it with the unprotected Panasonics in it and it was now pulling 3.4 in Turbo mode.
So two conclusions...first, how the hell are some of you getting way more draw than 3.4 in Turbo (what batts are you using??)? Second, TF 2600 Flames really suck! I thought you could easily pull more than 2.6A from them but apparently not.
Oh, I guess there is a third conclusion...with the right batteries the TR-3T6 isn't that bad of a light! :)
Johnny
PS: I really do LOVE my DRY!!
It's about time you experienced the DRY goodness. If you had to wait any longer for yours, I was going to send you a 'loaner.'
I use Callie's Kustoms, or AW cells in mine. IIRC, the highest draw on the CW I saw was over 4A, and just short of 3A with the WW.
Johnny, I was getting the same reading as you with the Panasonic's, and a little more with Xtar 18700's. Then I tried the Hi-Max 2600mah. Those give me 4.1 amps. I'd like to find 18650's that will allow for maximum current draw in the Dry
I get a reading of 4.6a with 3000ma flames..haven't tried my 2400 flames yet..
johnny -
I thought I read that some people were getting upwards of 5 amps? I don't know. I'm actually kinda glad mine pulls "only" 4.30. And, I'm glad you got your Dry.
So - thought I'd ask; anybody EDC their Dry? Of course I would never have been happy until I got one but, I tried actually . . . you know, using it as a flashlight. Certainly a wild notion but, I took it to work and . . . yeah well, handy it ain't. Great conversation starter but, Foy missed his L2P.
Foy
Thanks Johnny for the welcome.
I bought the Dry (the one with turbo that does not shut off after 20 seconds) and have the TM11, the TK70 and a few other less bright lights.
I have not been able to compare the dry to my newly acquired Electrolumes Bruiser since I sold my Dry to my Bro-in law (gonna order another today or tomorrow).
What I can say is that the Dry is certainly quite a light considering the $100 (including shipping) smackers. Certainly not as bright as the TM11 and definitely not as bright as the TK70 but for $100 it has got to be the absolute biggest bang for the buck.
The TM11 has more throw and puts out noticeably more light but does not dwarf the Dry.
The Bruiser, in my opinion puts out as much light (of course I am going off of memory) as the Dry but not as much as the TM11 (this is based on my eyes).
The bruiser has great build quality, one solid light. It is a very floody light and really lights up an immediate area, this will be my camping light.
The bruiser is smaller (than the Dry and TM11, actually a little longer but less fat) and uses only one battery (larger than an 18650) and has about a 20 minute battery life. It has only one mode and is press on and release off or screw on (similar to my first Surefire).
If anyone cares I will do a more complete review and include pictures of the lights side by side.
If you don't need much throw and want a really small pocketable (in my opinion) pocket rocket the Bruiser is not a bad choice.
The Elektrolumens EDC is similar to the Bruiser but smaller and not as bright. Both have very good build quality.
Actually the DRY has been measured by many folks here and CPF.... for the record, the TM11 and TK70 does not have more OTF output than the DRY.
If you check CPF, the Elektrolumens Bruiser does not give out a lot of lumens too.... It is DD and 3 LEDs parallel, so you already have a good idea as to how well it does "as a system". Try a King Kong or MKNE 26650 in there though.... (esp the MKNE, from my experience in the XTAR S1 is 3P).
But don't put 4.23V Sanyo 2400s into the DRY and play with strobe (I think the prev version have strobe, the 3-mode, i still have 4 of them drivers after selling 1 off to a local flashlight pal... LOL!). I fried one of the XM-Ls in my DRY drivered SR3800. This reminds me to put my 3 x U2s into the light....or maybe i should change out the DRY's T6.
Hmmmm, interesting that the Dry would be have more OTF Lumens.
When I get my new one I will check again but when I use the lights for inspecting chimneys and looking into crawl spaces, the Dry does not light it up like the other 2. I also ordered the brightest Dry.
Maybe I am using weaker batteries. I will order some unprotected ones with my new Dry.
Anyone else compare them side by side and find that the TM11 and TK70 have significantly more light.
You need to have better batteries. Trustfire Flames 2400s are good and cheap (get the protected cells). The DRY is a very simple yet effective device for its intended usage. 14mm MCPCBs mounted on a 3mm aluminum plate in a budget light host, lightly pressed down by the reflector, XM-Ls are direct drive in Turbo mode, hence batteries = output. No worries, there is usually enough chinese-brand thermal compound in there.
The easy way to check is just a current measurement at the tail. If that does not solve it, connect the tailcap up as well and measure. Best is about 3.8-4.0 amps. No need to go above that, but it would be fun next winter should it hit -30 deg C again in Europe because you do get about a 10% boost in lumens OTF. (I guess not too cold, as people do die from this kind of weather).
Try to get protected cells (nearly 100% safe), no way to tell when the driver can fail and give you a dead short scenario, but luckily it's extremely rare. But no telling when folks would abuse the drivers and just forget about it after that, eg by gunning the light in Turbo for 10 minutes @ 10 deg C ambient. (too hot...messes up the electronic components)
Thanks 2100!
Ha ha ha.
Gotta love forums. Had I kept my silly mouth shut I would simply think that the Dry was a great cheap light and I may not have bought another one because for me it was not as useful as the TM11 and not "nearly as bright".
Now that I have been corrected I can buy it again and this time get the right batteries so that it may actually replace my TM11 as my main holstered light.
Thanks guys for settin a nube straight!
Anyone know where to get these better batteries for the light?
Ha ha ha.
These will fit the holder and give you maximum light output.
http://www.intl-outdoor.com/panasonic-cgr18650ch-2250mah-liion-battery-p-291.html
I think the CGR18650CH would be too powerful, those are nearly like IMRs. Too much current and it goes poof in Turbo.
Trustfire Flames 2400 protected would do just fine. Get 6 for your 2 lights. They are protected and to date no PCBs have failed me.
