Prototypes can look bad, but function good. I wouldn’t focus on it unless it used inferior components. I will reserve all judgment until they are officially released and reviewed.
The real reason for Haikelite not putting in 4000k 80CRI emitters were not because they were hard to find. I easily found them at Mouser and Arrow, and I could easily order them myself.
The problem would be that the top bin of 4000k 80CRI is quite a bit more expensive than the lower bins, which is why Haikelite did not put them in their lights.
4000k
3000k (NASA had me install these into a GT for them, looks like an incandescent light, pretty neat actually)
In the real world the 80cri have a much lower forward voltage and usually are only a little behind the 70cri in lumens from my testing. For example the P2 4000k in my L6 was a bit over 9k lumens and my 80cri M4 bin 4000k is around 8500 lumens, it just pulls about a fair amount more current to do that.
I can also get different xhp35 HI tints as well:
70cri D2 bin 5700k
80cri C4 bin 4500k
80cri C2 bin 4000k
80cri C2 bin 3000k
XHP35 HD (HD has the dome still on it, a bit less throw but more lumens, I like them in everything but a dedicated thrower myself):
Former Haikelite USA distributor replied: “Almost forgot. I Spoke with Dale last night. Haikelite knows nothing of their brand listing on Aliexpress so a little warning. Purchasing those are totally non authorized and will not be covered by the brand in any way.”
I would double check with Dale to see if this is true though. I personally tend to think the lights are legit.
I just checked, but there is no option for Paypal. Maybe you can contact the seller and transfer money via Paypal; this is also possible with Simon from Convoy on Aliexpress.
