UPDATE 6
Payment sent, and order has been started. Letās get this GB ball rolling.
1. 1mm wire BeCu C17530 38% IACS has been ordered.
UPDATE 6
Can I get in on this?
Iād like 50 please.
Thanks!
50 big or 50 small?
Anyway, I will go to sleep.
See you tomorrow!
50 big AND 50 small
Thanks for making these available!!
10 small, 10 large springs, thanks!
Nice work BlueSwordM. :+1:
Protected batteries with high current springs? :confounded:
Itās not ideal, but there are protected cells with 15A and 20A circuits.
Where Jason, links pleaseā¦
I donāt have time to look them up right now, but Iāll try to remember where I saw them.
I think it was the 18650 from Imalent that did 15A which uses a 30Q.
Then the 20A was a 21700 5100mah from Acebeam.
Then I think there was a 26650 from Orbtronic that was 15A.
I think there were a few more and I know I wrote them in a thread, but I canāt remember where. I wish I could do a search for things I wrote across all the threads.
Iām not particularly into protected cells, but Iāll try and find the others later today if your interested.
Thatās a good lead, Iāll see if I can find them based on that. I donāt use protected either but if there are some really good ones out there I wouldnāt mind having some for testing and sharing purposes. While I donāt normally have someone else using my lights it would be nice to be able to have a cell that could run em as theyāre built to run and yet not be killed by someone getting over zealous.
You can , go to your account and then āmy postā type in what you said or keywords under search comments and apply.
It only searches in your post and only the keywords you typed. :+1:
Ok, so now that the sample testing is complete ( ) Iāll take 50 large.
Yes, it worked. Thanks
I found one more battery:
Imalent 4500mah 26650. It is also rated at 15 amps. I think it tests at 5000mah.
This was from the L6 thread. As always, just because a manufacturer says itās battery can do 15A or 20A doesnāt necessarily make it true. I would do a search to see if they have been tested before I bought them.
List has been updated again.
We are at 1666 big springs, and 1182 small springs.
Now, there are actually 20A capable protected cells?
They must be using quite powerful MOSFETs to achieve this, with especially low gate resistance.
I will take 20 big and 20 small.
We are at 1686 big springs, and 1202 small springs.
Appearantly. Keep in mind that the Acebeam 5100mah 21700 is a high capacity cell, not a high drain. Iām not sure what itās base cell is, but itās safe to say itās not rated for over 10A continous (it might be a Samsung INR21700-50E). The EC65 light itās used in draws about 15A, but only for a minute or less at a time. The protection circuitry still adds a bit of extra resistance so the voltage sag is greater compared to an unprotected cell. Both of these reviews have interesting battery tests. Maukkaās EC65 review. Toobadorz EC65 review.
Note that the EC65 has single springs on each end while drawing 15A. This light could definitely use these Beryllium Copper springs!
BlueSwordM, I need a clarification of how will the GB go.
First you order a batch of big.
If itās good, you order small ones too. Otherwise the GB ends without making small ones at all, right?
What will be the delay from one batch to another?
Can you just wait with sending big ones until the small arrive to ship them together for those of us who ordered both?
