Ok wut again.
Why can't I copy and paste the right links again and again?
EDIT: What kind of problem do I have? OH! It's because I'm directly copy pasting the text, not the links themselves.
Ok wut again.
@DB Custom, yes they do sell 5000k 90CRI:
You just needed to search for the right one. It took 10-15 minutes for me to find each one of them and compare to their datasheets.
I can’t answer all of those, but here’s at least a partial answer.
The light uses 350mA at the ~150 lm level, so it probably uses about 2 to 4 times as much power at the 250-600 lm levels you described. Maybe 700 to 1400 mA, which on a 3000 mAh cell works out to about 2 to 4.5 hours.
The LED itself is unlikely to ever burn out or need replacing, especially if you have the XP-L HI model. I hear the Nichia 219c may have some difficulty when used at turbo a lot, but it should generally still be fine for normal use. The main thing people have reported issues with is a broken switch wire. But that will generally show up right away, and shouldn’t really degrade over time. Or a couple people have managed to break the lens, but it’s pretty easy to replace.
They’re all dead but the links I copied and pasted.
That last one worked :+1:
Thanks again.
Now, here are the good links. I have manually checked them. The prices are in $CA:
5000k 90CRI:
4000k 90CRI:
3500k 90CRI:
2700k 90CRI:
Read em again BlueSword, the only way they sell the 5000K 90CRI they have in stock is in minimum quantity of 800.
Edit: Could well be the difference between Digi-Key in the USA vs Digi-Key in Canada.
Uh, my link says otherwise for some reason :exclamation:
DB it doesn’t list the led as 5000k 90 CRI but when you look at the part number and match to the datasheet, that’s what it is.
+1
This is why I posted the specific list of the links. So, members could order the right LEDs :+1:
If you click the product page, you can switch to ‘Digi-Reel’ packaging and buy ’em one-at-a-time, but they ain’t $1 each.
This is the US site.
I just changed the .ca to .com
I studied the Samsung spec sheet, learned the reasons for all the lettering and text in their label, and that’s what I go by. The Digi-Key in the US doesn’t sell the 90 CRI 5000K in singles. The 80 CRI ones I bought were $2.64 each as compared to $3.57 or so Canadian on the links posted above for the 90 CRI version. The Canadian site also has W6 power bins available that the US store doesn’t have at all. Now if we could only find the 96 power bins…
Ah, the devil is in the details.
I won’t buy an S6 power bin when W6 is the current highest available. 4 levels down in power, no thank you.
Edit: And following that last provide link shows a W6 in the US store, Digi-Key is SO confusing… I’ve spent hours in their store in the past few days and bookmarked the highest bins, searched it out all over again a few minutes ago and U6 was it, now that link shows differently, how I don’t know but there must be some discrepencies in their warehouses or something and it’s frustrating. lol
I’m trying to figure this out. For me it works DB. Clink my link above “US site” and try to order.
Okay, there it is. Not the same bin. But they do sell LH351D 5000k 90CRI’s
Yeah, I don’t mind getting decent CRI if I can get power, if I have to sacrifice too much in the power department I’ll go with an XP-L2 or SST-40 or whatever. No point in wasting time to build an underpowered light.
JK, to some degree… some lights demand something special and there are allowances that can be made. lol
Edit: FTR, I searched it out new a little while ago and specified Samsung, LH351D, and 90CRI… the only thing they stocked showed 800 counts. Odd, their site is apparently unreliable. Crazy…
From Digi-Key’s US site:
From Samsung’s datasheet:
It seems their ‘minimum order’ quantity won’t prevent you from adding a single emitter to the cart.
So, yeah, that’s the highest possible bin for a 90CRI+ 5000k LH351D.
No such thing when I ordered the other day, I paid $21.21 for 6 of the 5000K 80 CRI emitters, shipped was $3.75 USPS and $1.62 tax. 3 days to my door.
I build for power first and foremost, if it can’t make the numbers I don’t buy it. Unless of course the light demands something special and high color rendering index is the flavor of the day, there have been exceptions but very rarely do I undercut the power first requirement. I’ve even ordered emitters from Cutter in Australia to get what was otherwise unavailable to me, yes, at $25 shipping. In a case like that I’d buy other things too in order to warrant the costs of shipping Internationally.
This was my first experience with Samsung emitters. They do well in my D4 as a Quad, not so much singly in other lights. Ok, and with nice color, but not overwhelming. I’ll use more, sure, but it’s not an easy go-to choice.
